10-25-2011, 02:30 AM
Handsfree Solutions
Hi Guys
Have juts bought my first Porsche, a 1999 Boxster, loving it.....
Looking to see what people use as a handsfree? im using iPhone so ideally would like music and handsfree phone usage
Cheers guys
M
10-25-2011, 06:22 AM
It's next to impossible to talk in the car with the top down, windows up no matter what kind of handsfree you use.
10-25-2011, 07:07 AM
I can imagine, but living in ireland, roof won't be down much.....Just lloking to try and make things legal etc
10-25-2011, 09:59 AM
I have purchased a sony CD player that has a built in bluetooth handsfree kit, looks brilliant, but im having trouble fitting, anyone fit one of these?? connections just dont meet up? small yellow block doesnt fit into new sony headset
10-25-2011, 11:47 AM
You will need a conversion adaptor for Sony connection and make sure alarm wire that was connected to old unit is grounded.
Not sure which model of Sony you have but can go on most audio sites and put your model car and radio in and it should show which adapter you need.
http://www.crutchfield.com/m_266150/Car-Stereos-Components.html
10-25-2011, 11:56 AM
It's a Sony MEX-BT2900 that I've bought, I've fitted them before, have spliced wires to get them to work but I really want to avoid that on this car
10-25-2011, 12:01 PM
That little block, where does that connect? Looks like what I need???
10-25-2011, 12:06 PM
That white connector should plug into the factory harness on the car. then you solder those leads onto the leads on your Sony stereo harness. Its a different harness if you have Nav from the factory...and it might be different if you didn't have door speakers. Use their configurator to help you out.
10-26-2011, 01:17 AM
Car Stereos & Components at Crutchfield.com
When you say grounded, where do you mean to? just earthed anywhere?
10-26-2011, 01:26 AM
I've found this, and it states that i do not need any installation kit? is that an adapter its referring to? this is exact sony player i have with my exact car's details in
Sony Xplod MEX-BT2900 CD receiver at Crutchfield.com
10-26-2011, 10:47 AM
Opposed to Subie Burble
In the future I'd probably want to get a 2DIN head unit with nav and BT, but in the meantime I'm using my BT headset when driving. Doesn't work too great, as my headset tends to pick up the engine noise over my own voice and the only time I can be heard fine is at a stop, and that's top up. Top down I can't be heard above 40mph even with all the turbulence minimizing in effect (deflectors between and inside roll hoops, windows up, visors up).
ABQautoxter's solutions seems interesting, especially if it works.
-O/D
IMSR + RMS
Robbins glass window top
10-26-2011, 11:25 AM
I got the problem sorted with an additional wiring harness, but my BT won't work with calls, plays music from my iPhone over BT but no sound when calling?? Any ideas on this matter?
10-27-2011, 07:15 AM
Not compatible with your model phone?
-O/D
IMSR + RMS
10-27-2011, 07:39 AM
Originally Posted by ABQautoxer
X2 I have one of these as well and it works very well. It is in my Range Rover and not my Boxster though but that is the nice thing I can take it with me in any car.
2001 Boxster S 3.6L, Zeintop
