Old 10-13-2011, 09:03 PM   #41
Jager's Avatar
What if they had a direct line into Jake Raby while they were doing it ? Hey, this has the makings of a TV reality show !! What would it be called ?
It would be called: THAT'S NOT WHAT JAKE SAID TO DO!
Jäger
300K Mile Club
Old 10-14-2011, 05:50 AM   #42
Johnny Danger's Avatar
If we could get an overweight Walmart employee, we could call it "Jake and the fat man " !!
Old 10-14-2011, 07:48 AM   #43
landrovered's Avatar
Only if they knock knuckles and shout "Jake and Bake!"
2001 Boxster S 3.6L, Zeintop
Old 10-14-2011, 10:12 AM   #44
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by DenverSteve View Post
The price for the supplies is why I pay for my work. At $9 per quart, that's $81 plus tax for oil alone. Add in the filter and your 80% to a professional oil change. It's not worth my time as I can make money while they work on my car. That's not even including the proper disposal of the used oil.
This has earned a touché. Well said, sir. For those who want the savings and have the time, you have the option to DIY. For those without the time and/or maybe the desire to wrench their own car, or any other multitude of reasons, there are the experts you pay a premium to for the convenience of not using your own time to work on the car. I'd love to wrench my own car more often than I do, but I find that if the car needs something and I don't have the time to get at it, might as well let someone else who makes it their business to have the time do it for me.
-O/D
IMSR + RMS
Robbins glass window top
Old 10-14-2011, 10:14 AM   #45
Overdrive's Avatar
This post needs a "Like" button.
-O/D
IMSR + RMS
Old 10-14-2011, 05:42 PM   #46
barkinfool's Avatar
if you've ever seen "People of Walmart" - in the realm of a new reality show, i propose "Mechanics of Walmart"
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
Old 10-15-2011, 01:24 PM   #47
I've found the Mobil 1 0w-40 didn't improve the cold startup rattle on my high mileage 2000 S. I was hoping that the thinner oil would hit the chain tensioner quicker and thereby eliminate the sound. If anything the sound is a little worse. It might be stopping a little sooner than before but I'm not sure. It stops within a second of the motor starting so I'm not too worried but the 0w-40 wasn't a miracle cure.
Dale_K is offline   Reply With Quote
Old 10-16-2011, 12:09 PM   #48
Overdrive's Avatar
I don't think it was ever expected to be...usually people talk about moving away from Mobil 1 to get rid of the rattle on startup by going to a different oil. I'm running Motul right now, and the noise at startup happens less frequently for me now, usually only happens after the car's been sitting for a few days between starts, and goes away faster than it did on Mobil 1. But it could have to do with a lot of things, and I've yet to run the car on this oil during the wintertime to see how it performs.
-O/D
IMSR + RMS
Old 02-05-2012, 03:19 PM   #49
Jager's Avatar
OK Paul I just ordered some Red Line 5W-40 I will report my experience after my next oil change.
Back in October said I would try Red Line synthetic oil. I purchased a case from Racer Parts Wholesale (best price I could find), and with my last oil change poured 9 quarts into the Jägermobile. The first thing I noticed is on cold starts there is no more lifter/valve train noise, which is something I would hear for about 10 seconds after startup, I still have a little chain noise until the tensioners pump-up but it’s much quieter on cold start-ups. I also notice it takes more time for the engine to come-up to temperature, which was a surprise. The next thing I need to check is how much ferrous metal is sticking to the magnetic drain plug when I change the oil next time (in a couple months). I will take pictures and compare with previous pictures/amounts when using Mobil 1, I will post those results. So far I am sold.
Jäger
300K Mile Club
Old 02-05-2012, 09:48 PM   #50
Idaho Red Rocket 3's Avatar
What is the weight of the Red Line you used ?
2000 Boxster S
Old 02-06-2012, 07:34 PM   #51
Jager's Avatar
I am currently using Red Line 5W40.
Jäger
300K Mile Club
Old 04-09-2012, 07:43 PM   #52
Jager's Avatar
OK Danger, I just changed my Red Line motor oil and did a comparison of how much ferrous metal was on my magnetic drain plug as compared to using Mobil 1. I consistently change motor oil every 3500 to 4000 miles and ran my last oil change of Red Line 5W 40 running just over 4000 miles to make sure I had a good comparison. I can without a doubt say there is much less wear (less metal on the magnetic drain plug) using Red Line. There was approximately 50% of the ferrous metal on the magnetic drain plug as compared to the amount found using Mobil 1. I attached a couple of photos of my drain plug, one showing how much ferrous metal was on the plug while using Mobil 1 (this was a consistent amount found on multiple Mobile 1 oil changes), and the second photo shows how much ferrous metal was on the magnetic drain plug after running Red Line. Unfortunately I did not have my camera set correctly and my second photo sucks. You can still see the difference even though it’s a bad photo (I will have to make sure my camera is setup correctly next time I change my oil so I can take a better picture).
Mobil 1
Red Line
I wish I had known about Red Line 200,000 miles ago.
Quieter startups
Motor takes longer to warm-up
Less wear on the motor
Jäger
300K Mile Club
Old 04-10-2012, 06:29 AM   #53
Jager, to track metal wear, try doing used oil analyses. I've done several on my car and other than the wear metals going consistently down since I got the car and did oil changes at 3k intervals, i haven't found one oil that is consistently better than the rest.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-10-2012, 06:42 AM   #54
Overdrive's Avatar
Jäger, I'm curious about what you see as an advantage of the car taking longer to warm up? Or maybe my question should be do you see that as an improvement or was it simply an observation?
I don't daily drive my car like you do, but I would personally want to see my temperatures reach optimum as quickly as possible so I can drive the car harder sooner.
-O/D
IMSR + RMS
Old 04-10-2012, 02:07 PM   #55
Moderator
I used Mobil 1 10w-40 high mileage on my 76k boxster last oil change. I was looking to buy Pennzoil Ultra 0w-40 but it was not sold at walmart.:ah: The advertisements claims it "cleans better" than mobil 1 so given the choice I'd pick that. Plus it's the official motor oil of Ferrari north America.
Old 04-10-2012, 02:37 PM   #56
The pictures of the magnetic drain plugs are nice, but it means very little. The only way to know if your wear metals have decreased, increased, or holding steady, are with UOA's.
Old 04-10-2012, 05:37 PM   #57
Jager's Avatar
I agree oil analyses is the best way to determine metal wear but this was such an obvious visual difference I had to share. I have put close to 200,000 miles on my Boxster (car has over 228,000 miles on original motor) and I can honestly say Red Line motor oil is much different than Mobil 1.
Jäger
300K Mile Club
Old 04-10-2012, 05:41 PM   #58
Jager's Avatar
It's just a simple observation. I agree, it would be best if the motor started at 180 degrees, oil is designed to perform warm.
Jäger
300K Mile Club
Old 04-11-2012, 07:59 AM   #59
Originally Posted by Dale_K View Post
I just changed my oil yesterday after finding a Walmart with Mobil 1 0w-40 in stock for $6.47 per quart. Too bad they didn't have the 5 qt. jug anywhere locally. I'll add a post after some colder weather if I notice a significant change in the start up noise in cold weather.
If you can't find the 5 qt jug order it online for in store pick up. They dont seem to stock their shelves well for some reason.
I just switched over from 0-40 to 10-40. Lots of noise on start up. This oil thing is driving me nuts. Then again maybe 10-40 in summer and 0-40 in cold weather maybe the way to go for me.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 04-13-2012, 10:21 AM   #60
Jäger,
Glad to hear you're enjoying Redline. I have had the same experiences as you except I can't comment on the warmup time (because I never noticed it). I have a couple of thousand more miles to do before I change out the oil and get an UOA -- I'm also interested to see what the Fe levels are.
Regards,
paul...
paulv is offline   Reply With Quote
