Old 09-08-2011, 06:17 AM   #1
Light weight Boxster racer
Here's latest pics of the car I built under new ownership. I did get to drive it at SCCA Solo Nationals in Lincoln. What a blast!
http://www.youtube.com/watch?v=vxJR5pKl9bE
grantsfo is offline   Reply With Quote
Old 09-08-2011, 06:26 AM   #2
wow; looks like fun! what have you done to the motor? sounds like more than 6700 RPM...
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 09-08-2011, 08:44 AM   #3
Stock motor with headers and exhaust system from Precision Chassis. At under 60 MPH we were under 6500 RPM as we were on tall 18 inch tires. Car just sounds like its spining like crazy. It does have rev limiter disabled but like all stock 2.5's it makes no power over 6000 RPM.
Old 09-08-2011, 01:40 PM   #4
Wow, car looks to perform great in that video! What kind of wheels are those?
I've seen their exhaust system, but haven't seen their headers. Do you have any pictures by chance?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 09-08-2011, 03:43 PM   #5
Headers were $99 specials on ebay.
Old 09-08-2011, 11:15 PM   #6
Oh okay, gotcha... Thanks!
Old 09-09-2011, 03:46 PM   #7
The wheels are CCW classic 3-piece wheels 18x11". Using 285/30/18 front tires and 315/30/18" rear tires. The passenger side header was modified as it had a crimp in it, but don't see much area of improvement in a higher priced unit.
BTW, anyone know where I can buy or have made camshafts for the 2.5 liter motor with limit of 0.500" lift on exhaust and intake? I plan on running the car in E Production road racing and that is the limit.
Grant built a good car, as with just some modification to the wheel and suspension setup, the car set top time on the west course at the SCCA Solo Nationals in FP. It needs a 2.7 liter to fit into the weight parameters better, as it is 140lbs overweight using FP's 0.75x(discplacement in cc) formula, plus 100lb added for wheel size over 10".
3RotorRx7 is offline   Reply With Quote
Old 09-10-2011, 01:42 PM   #8
That is awesome!
Old 09-10-2011, 03:38 PM   #9
The Radium King's Avatar
raby sells a hot cam for the boxster, but i don't know the grind or if he does custom.
