Old 08-20-2011, 08:59 PM   #1
Tony
Brake pad warning light on after pad change ?
I've just changed the front pads and rotors (including the wear sensors) on my 2001 Boxster S for the first time. It all went ok. To my disappointment however the brake pad warning light came on as soon as I turned on the ignition to go and bed-in the new pads. Hmmmm...what the heck did I do wrong?
Any suggestions what it might be / how to resolve easily ?
tony63422 is offline   Reply With Quote
Old 08-20-2011, 11:40 PM   #2
Most likely one of the pad sensors isn't making good a good contact where it plugs in or the sensor itself is bad (broken internal wire). I'd remove the sensors where they plug in and test them for continuity using a multimeter. Then re-seat them firmly and see if that fixes the dash light problem.
Old 08-21-2011, 07:39 AM   #3
Porsche "Purist"
Paul's Avatar
Unplug one at a time until the light goes out.
Once you find the culprit, check the sensor for a short to ground.
1987 924S. 2002 996TT. PST-2
