Old 07-14-2012, 02:39 PM   #2
2003 removal
for '03 there aren't any tabs to punch I could find. There is a plastic piece that's painted, the only part you see when the spoiler is retracted. Squeeze this towards the rear of the car, look at it from the underside, you will see some tabs. As you squeeze it rearwards, these will clear and that plastic painted piece will pop off. Then there are two allen screws that remove the aluminum main part of the spoiler. Once that's off, retract the spoiler again to get full access to the screws you need to remove the bumber. I just did mine, WAY easier to not mess with the license plate ilghts, just remove the spoiler and before you walk away with it, uncouple it. The connector is hidden behind the bumper until it's off, right behind the ilcense plate.
stavinski is offline   Reply With Quote
