Old 06-30-2011, 08:55 AM   #1
Ok to use Permatex gasket maker on oil sump plate.
This weekend I plan to pull the oil sump plate to see what's inside there, hopefully not pieces of my IMS bearing. Porsche says to use some exotic gasket maker when putting it back together. Will Permatex red, high temp RTV gasket maker work?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-30-2011, 09:05 AM   #2
madmods is offline   Reply With Quote
Old 06-30-2011, 09:45 AM   #3
The Radium King's Avatar
LN Engineering uses Loctite 518 instead of OEM for their sump stuff (good luck frinding driebond - threebond - anywhere).
Old 07-06-2012, 02:44 AM   #4
Originally Posted by madmods View Post
I've used some "found in China" RTV high temp liquid victor gaskets around the water pump and still today it looks as new. Guessing you are good to go with anything high temp RTV but always better to listen to the pro and use the (Porsche) proven stuff first.
Bump. True. Don't just go for something that haven't been tried or proved that have actually worked. Better ask the pro or experienced consumers.
kotto is offline   Reply With Quote
Old 07-06-2012, 07:10 AM   #5
Permatex red works fine, but its imperative to use just the slightest amount of sealant. Less is more. You have to lay a tiny bead, 1mm at the widest, all around the plate.
If you goober it, the sealant will squeeze out into the sump and can clog the oil intake tube.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 07-06-2012, 02:06 PM   #6
BYprodriver's Avatar
Porsche service manual specifies 1.5mm
Old 07-06-2012, 12:18 PM   #7
Its a good idea to have a look. My sump was amazingly clean and free of any debris whatsoever. And as San Rensho said, use the least amount of sealant that will get the job done.
Old 07-06-2012, 03:19 PM   #8
And make sure both surfaces are ABSOLUTELY clean!
Lon Tusler
1999 996, Track Only #996
Everything Jake could upgrade, and more!
ltusler is offline   Reply With Quote
