Old 05-19-2011, 05:06 PM   #1
Question Rear View Mirror
The rear view mirror on my 2004 Boxster decided to pop off..!! Do you think I can get it back on..I have tried and tried. The mirror and the holder both came off, the mirror is now off the holder but I cant get the holder on the window..I think you must just put it on and twist..but hwo hard? Then getting the mirror on that..do you just push hard..?? Help..and thanks in advance
tedd is offline   Reply With Quote
Old 05-19-2011, 05:43 PM   #2
is the button still on the glass itself? If so, the stem as I recall is attached to it by putting on and then turning 90 degrees clockwise to lock into correct position (you will need pliers to do so and make sure you protect the finish w/ some towels, etc.).
Good luck
Old 05-19-2011, 07:33 PM   #3
Rear View Mirror
[QUOTE=Burg Boxster]is the button still on the glass itself? If so, the stem as I recall is attached to it by putting on and then turning 90 degrees clockwise to lock into correct position (you will need pliers to do so and make sure you protect the finish w/ some towels, etc.).
Good luck [/Thanks so much. Yess the button is still on the glass. I was able to turn it about 75 degrees by hand but was worried about cranking it more. So I will use pliers and a cloth to do that. Any idea then on how to attach the mirror to that..just push real hard..?? Thanks again
Old 05-27-2011, 08:33 AM   #4
Rear View Mirror Solution
[QUOTE=tedd]
For those with this problem in the future, I thought I should follow up with the answer! Burg Boxster was quite right. To get the mirror holder back on the "button" that is glued on the windshield, just use vice grips ( and a cloth) and crank it 90 degrees. The hard part is if the mirror is actually off the holder as mine was. You have to use quite a bit of force to push the holder into the mirror..but it will go. If you break the mirror though you are in trouble so I was able to pop the mirror off first. Finally the switch to adjust the mirror from day to night goes on the bottom so it is a bit difficult to get it all back on the windshield..but it does fit! Good luck.
Old 05-27-2011, 09:03 AM   #5
Glad it all worked out. Hope there's a good story as to how it got knocked off... next time though it might be easier to just re-detail your hood
Old 05-27-2011, 12:14 PM   #6
jaykay's Avatar
Ah so to remove/unlock a mirror one just grabs on and rotates?
986 00S
Old 05-28-2011, 12:24 PM   #7
kpm
Do I count 6 fingers on her left hand ??
kpm is offline   Reply With Quote
Old 05-28-2011, 12:59 PM   #8
The six-fingered woman!
My name is Inigo Montoya. You killed my father. Prepare to die!
Wait, never mind, that was the six-fingered man......
'99 black 986
