[QUOTE=tedd]
Originally Posted by Burg Boxster
is the button still on the glass itself? If so, the stem as I recall is attached to it by putting on and then turning 90 degrees clockwise to lock into correct position (you will need pliers to do so and make sure you protect the finish w/ some towels, etc.).
Good luck  [/Thanks so much. Yess the button is still on the glass. I was able to turn it about 75 degrees by hand but was worried about cranking it more. So I will use pliers and a cloth to do that. Any idea then on how to attach the mirror to that..just push real hard..?? Thanks again
For those with this problem in the future, I thought I should follow up with the answer! Burg Boxster was quite right. To get the mirror holder back on the "button" that is glued on the windshield, just use vice grips ( and a cloth) and crank it 90 degrees. The hard part is if the mirror is actually off the holder as mine was. You have to use quite a bit of force to push the holder into the mirror..but it will go. If you break the mirror though you are in trouble so I was able to pop the mirror off first. Finally the switch to adjust the mirror from day to night goes on the bottom so it is a bit difficult to get it all back on the windshield..but it does fit! Good luck.
