Old 05-09-2011, 03:50 PM   #1
Johnny Danger's Avatar
Code P0102 ?
Sorry if I am perseverating on this issue, but before I spend $200-300 on a new MAF sensor, has anyone else dealt with this code before. The reason for my concern is, after inspecting and sensor it appeared to be as clean as a whistle with no signs of dirt or contamination (i did clean it nevertheless) . Also, as far as I could tell, the plug harness and wires seemed ok as well . Do MAF sensors simply have a self life to them (I have an '02 S with only 18k original miles), because I am experiencing a rough idle ?
Old 05-10-2011, 06:37 AM   #2
If you have a Durametric tool, you can check the actual value of the MAF sensor (with ignition on) voltage -- it should be 0.9 to 1.1 volts. With ignition on, and engine idling (and warmed up), it should be between 1.2 to 1.5 volts.
Regards,
paul...
paulv is offline   Reply With Quote
