Thread: Code P0102 ?
Old 05-10-2011, 07:37 AM   #2
paulv
If you have a Durametric tool, you can check the actual value of the MAF sensor (with ignition on) voltage -- it should be 0.9 to 1.1 volts. With ignition on, and engine idling (and warmed up), it should be between 1.2 to 1.5 volts.
Regards,
paul...
paulv is offline   Reply With Quote
