-   -   Code P0102 ? (http://986forum.com/forums/performance-technical-chat/28821-code-p0102.html)
Johnny Danger 05-09-2011 04:50 PM
Code P0102 ?
Sorry if I am perseverating on this issue, but before I spend $200-300 on a new MAF sensor, has anyone else dealt with this code before. The reason for my concern is, after inspecting and sensor it appeared to be as clean as a whistle with no signs of dirt or contamination (i did clean it nevertheless) . Also, as far as I could tell, the plug harness and wires seemed ok as well . Do MAF sensors simply have a self life to them (I have an '02 S with only 18k original miles), because I am experiencing a rough idle ? :confused:
paulv 05-10-2011 07:37 AM
If you have a Durametric tool, you can check the actual value of the MAF sensor (with ignition on) voltage -- it should be 0.9 to 1.1 volts. With ignition on, and engine idling (and warmed up), it should be between 1.2 to 1.5 volts.
Regards,
paul...
