Old 05-04-2011, 07:53 AM   #1
Front Suspension noise.
Hello everyone.
I have a 2000 boxster that I just installed the Eibach pro-kit lowering springs. After I installed the springs, I now have a metallic clunking sound in the front.
I also had the same sound in the rear, but replace the rear track arms, and now it doesn't exist. This front sound is almost identical to the rear sound I had.
I know its not anything loose because I doubled checked everything in the front including the strut towers.
Has anyone experience this? I am speculating it can be the front A-arms, but i dont want to spend $300 to replace them if im not 100% sure.
theitalianflip is offline   Reply With Quote
Old 05-04-2011, 08:11 AM   #2
could also be the sway bar links. disconnect the sway bar & see if the sound goes away.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 05-04-2011, 01:10 PM   #3
Good idea, i think ill try that
Old 05-05-2011, 08:33 AM   #4
manolo's Avatar
Also make sure the the studs for the three strut mounts are aligned properly and resting in the plastic "cup" correctly. Like this:
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 05-05-2011, 02:28 PM   #5
I did double check to see if they were fitting in the cup and they were. Also, i noticed in the pic you provided that the struts have the rubber ring on the top. I had the ring on my rears, but not on the fronts.
Old 05-05-2011, 03:28 PM   #6
manolo's Avatar
Its not my picture, I stole it from someones site. For a parts diagram blow-up, check www.********************************************.com
2003 Cayenne Turbo
Old 05-10-2011, 07:40 AM   #7
thanks manolo
