Old 12-28-2010, 10:06 PM   #1
Idaho Red Rocket 3's Avatar
Thank you all very much. Not sure I understand the series of engine numbers, but I'll find out what engine number is in the car to compair against the list.
BTW, which size bearing is NOT replacable while engine is intact ?
Single ?
Double ?
Something Else ?
Old 12-29-2010, 05:53 AM   #2
Engine Surgeon
The non-replaceable unit is the large diameter single row bearing. It has a 22mm retaining nut.
US Patent 8,992,089 &
US Patent 9,416,697
Old 12-29-2010, 06:30 AM   #3
Jake, Thanks in advance.
Despite the already upgraded to a larger IMS in MY06-08, you still see some failure. What is the comparison between the MY06-08 with your retrofit IMS?
If it need to be tear down the engine to do the retrofit, is it worth it.
Cost wise?
I just bought an 06 boxster S with 2 year CPO. Thinking about retrofit it and keep it for a while or dump it after CPO run out.
lifeisgood is offline   Reply With Quote
Old 12-29-2010, 07:21 AM   #4
Engine Surgeon
Cost wise?
Their isn't a comparison between the two...
Currently MY 06 vehicles are just coming out of warranty, most of the reports we have heard so far of these bearings failing have come from Dealerships that slipped us some info. Now that these can't be swept under the rug as easy the reports should elevate a bit, like they did with the earlier cars.
LN and I have already produced a ceramic bearing for the MY 06, large IMS, it is in testing in a full blown track car.
Cost wise: If I tear into an engine I ONLY fully upgrade it, I refuse to just open it up and swap the IMS, because thats a waste of effort and leaves a dozen more points of possible failure in existence. Prices for a fully upgraded FSI engine start at 16K, (most are 18-20 and can reach 22-25K) but the least of those makes 30HP more than factory and includes installation, assembly by a single Human and dyno optimization.
US Patent 9,416,697
Old 12-29-2010, 09:52 AM   #5
But how is a track car
a test of how a ceramic bearing will perform in the cars we have and the many of us drive?
I recall your comments that cars driven gently (and specifically TIP cars because that transmission's shift patterns promotes low-rev higher-MPG driving) suffer more failures than cars driven at high RPM.
It would seem that a track car would be testing in a very different driving style than the street car norm..or is your car babied around the track at less than 3k RPM? I'd have thought that Atlanta traffic at rush hour would be a better test environment than Road Atlanta.
Old 12-29-2010, 10:28 AM   #6
Engine Surgeon
Mike,
More will come in street cars. This one got applied to the track car for many reasons.
We have lots of time, we won't be seeing the majority of these cars equipped with the larger diameter bearing for 2-3 more years.
The larger diameter bearing responds to engine RPM differently.
It is more difficult to carry out development and check up on the larger diameter bearing, since it can't be removed without complete teardown..
At the present, if we update an MY 06 or newer engine, we back date the IMS and use the triple row IMS update, something thats proven.
US Patent 9,416,697
Old 12-29-2010, 11:57 PM   #7
I just found another MY06 with a build date of 8/05. It is a base with Sport Chrono. Would this car be more safe than the 10/05 built car ?
