Old 12-01-2010, 10:08 PM   #1
TechnoTorque or Underdrive Pulley
Trying to decide which to do for my next mod,
both are roughly the same price, any thoughts?
thanks
dsisco is offline   Reply With Quote
Old 12-02-2010, 05:53 AM   #2
Carnut
AndyA6's Avatar
Both of course!
I just got the RSS UD pulley, next will be the TT. Also depends on your car but the pulley will give you more I think.
'14 Boxster
Old 12-02-2010, 07:36 AM   #3
What are your thoughts on the pulley? worth it or not?
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
MikenOH is offline   Reply With Quote
Old 12-02-2010, 08:24 AM   #4
Johnny Danger's Avatar
thanks
My vehicle is equipped with both of them, and I am very pleased with their performance . However, you'll find that there are highly polarized views on this site regarding the effectiveness of Techno Torque . Personally, I feel that there is merit to Pedro's design given the proper application. As far as the light weight under drive pulley is concerned, most will agree that its one of the best "bang for buck"mods one can perform on their boxster. Moreover, there's ample data on this site and others to suggest real gains in hp .
Old 12-02-2010, 09:30 AM   #5
kyleturner2020's Avatar
I just installed the pulley a few weeks ago. It is awesome! I highly recommend it. As far as the TT, I'm waiting on the 75mm throttle body and ipd plenum to be realeased for 986 in about a month.
Kyle
2000 Boxster S
2007 H3
kyleturner2020 is offline   Reply With Quote
Old 12-02-2010, 10:58 AM   #6
Carnut
AndyA6's Avatar
Wait what?!
IPD plenum and 75mm throttle body?? For our cars? That will be interesting to say the least. It seems this setup works very well on Caymans etc.
Too bad this will be like what, $ 1,000??
'14 Boxster
Old 12-02-2010, 11:22 AM   #7
Carnut
AndyA6's Avatar
Found this link
http://www.speedmerchants.com/products/ipd-intake-plenum-986-boxster
I will start saving some $$$!
'14 Boxster
Old 12-02-2010, 12:16 PM   #8
Originally Posted by AndyA6
Wait what?!
Word on the streets is 1000-1200 for a package deal. I can't wait!! My car will be pretty much maxed out without you know: a bigger motor
Kyle
2000 Boxster S
2007 H3
Old 12-02-2010, 12:34 PM   #9
Rennzenn
j.fro's Avatar
I've got a 75mm TB with a stock 996 intake "T" on my 3.2. It opened up the mid range very nicely. Don't ask for dyno sheets - that's coming in the spring.
Old 12-02-2010, 01:30 PM   #10
JAAY's Avatar
Underdrive Pulley.
Old 12-02-2010, 04:42 PM   #11
Steve Tinker's Avatar
+1 on what JAAY said........
2001 MV Agusta F4.
Old 12-02-2010, 06:00 PM   #12
Thanks guys for the feedback,
My water pump has just blown so looks like ill be doing the pulley while im in there.
will order from Tarret engineering or flat 6,
any reccomendations? or are they all pretty much the same?
will let you know how it goes
thanks
Old 12-03-2010, 05:53 PM   #13
thanks
I've asked the same question on other forums and have not gotten an answer.
I think there are 4 UD pulleys that are out there:
RSS
Mantis
Flat 6
BBI
Again, any difference between these four?
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 12-03-2010, 06:39 PM   #14
thanks
I installed the BBI on my vehicle about a year ago . At the time, it was considered the lightest and best designed pulley of the lot. However, Jake at Flat 6 has since come out with his own which I'm sure is excellent also.
Old 12-09-2010, 09:30 PM   #15
ended up going with the newest design from BB1 from tarrett engineering,
will be installing over the weekend along with my engine mount, water pump and LN thermostat,
will let you know how it goes.
ps. is there any gains to be had from removing the cats on a 2.5?
thanks
Old 12-09-2010, 09:57 PM   #16
JAAY's Avatar
8hp. and a check engine.. Fabspeed makes some sweet bypass pipes.. That is what I am running.
Old 12-10-2010, 09:09 PM   #17
"ended up going with the newest design from BB1 from tarrett engineering"
Are you changing to a shorter belt as well, or were you going to see if the oem belt works? Any trouble with grinding down the boss that apparently is in the way?
Be nice to see some pics!
Mark
'99 black 986
Old 12-11-2010, 11:34 PM   #18
how do you get rid of the check engine light?
Old 12-12-2010, 06:19 AM   #19
To clear the CEL, you would have to reprogram the ecu in order for it to disregard the fact that the cats have been deleted. In my experience, going "catless" resulted in a significant loss of low end and mid range torque. Since the 2.5 engine only has one set of cats, you would be better off upgrading to a set of high quality lower cell units. This, however, can be an expen$$$$ive .
Old 12-12-2010, 07:51 AM   #20
JAAY's Avatar
Probably true on the 2.5. I have a 3.4 so in my case it is different.
