Old 05-07-2005, 05:15 PM   #1
Lux
Talking Changing Air and Pollen filter. A pictorical (56K beware)
Just got done doing a couple of things in the 15K minor service (although I'm only at 12K...what the hell). Attached is a little pictorial. Surprisingly, the air filter looks practically new. The pleats were clean and the foam outer side was clear. The pollen filter, on the other had, was nasty. I've got my fan running all the time so I'm sure that didn't help.
Lux is offline   Reply With Quote
Old 05-07-2005, 05:17 PM   #2
Lux
Oh yeah, here's a glamour shot.
Old 05-07-2005, 05:22 PM   #3
Brucelee's Avatar
Talking
Great stuff! We are intending to create a "how to" section with exactly this type of permanent posts. Thanks much!
One question-on the photo of the engine, I assume you are looking down through the opening right behind the rolll bars, correct? If so, can you describe how you got down there?
Also, I have found that a good vacuum with deep brushes will really get that pollen filter quite clean. I would NOT use that technique on the air filter but with the pollen filter, it will be fine.
Those pollen filters are very expensive, no?
Thanks again!
Old 05-07-2005, 05:57 PM   #4
Lux
Yes, those pollen filters are insanely priced. Especially the charcoal-filtered ones. I think I'll take your advice and vacuum it out every 3K miles or so since it's pretty easy to access.
I think you're asking if the photo was taken looking towards the back of the car from inside the cabin? If so, that is incorrect. The photo was taken from the back of the car looking forward. When the top is in the "service" position the clamshell that covers the top is fully open (see attached pic).
Old 05-08-2005, 02:29 PM   #5
Hey Lux, I'm going to do the 15k mile service myself as well and I was just wondering how long it took to do the Pollen Filter? What tools are needed?
Old 05-08-2005, 03:00 PM   #6
Brucelee's Avatar
The pollen filter takes about 5 minutes tops. You need a torx set for one screw in the middle of the plastic panel. Remove it, pull off panel, pull out filter, put in new one, reverse.
Old 05-08-2005, 05:01 PM   #7
excellent. Thankyou.
Old 05-08-2005, 07:02 PM   #8
Perfectlap's Avatar
wow the dealer wanted 300-400 for this?
I went in for the oil change $200 and told them to swap the air and pollen filters.
They said that'll be $600 and we need the car ALL DAY.
Old 05-08-2005, 08:03 PM   #9
LOL...I believe it. Your basically paying 600 dollars for something anybody can do with 1-2 hours to spare..oh yeah and you get a little stamp in your Porsche service manual. That's one expensive stamp.
Old 05-08-2005, 08:39 PM   #10
Lux
Yeah, it's a 3 minute job. Take off the battery cover, unscrew one torx bolt and remove the second cover that hides the pollen filter.
One thing you want to be careful about when removing the 2nd cover:
It slides out. Pull it towards the front of the car (don't try to pry it upwards or anythiing). When you see the snaps you'll know what I mean.
Old 05-09-2005, 07:09 AM   #11
Brucelee's Avatar
Talking
It IS easy to rip the filter so the tip above is very useful.
Old 05-09-2005, 12:15 PM   #12
Perfectlap's Avatar
ok so where's the best place to get these filter CHEAP(in the P-car sense of the word).
I'm planning on buying them and going to my nearby Mobil 1 and talking them through it, as I watch. I need the stupid ASE certified receipt for my extended warranty.
Old 05-09-2005, 01:16 PM   #13
Brucelee's Avatar
I have not found a cheap pollen filter--$32 is the cheapest I found at Kragen.
The air filter I am still searching the parts stores. The list is $36 I beleve.
Old 05-10-2005, 08:45 AM   #14
Perfectlap's Avatar
LUX,
did you notice a difference in performance after putting in the new filters? I know that when I recharged my K$N filter on the old car, the difference was tremendous. Ditto on my friends bike.
Old 05-10-2005, 04:32 PM   #15
Lux
I really didn't notice any difference. Matter of fact, my old air filter looked remarkably clean.
I think there's also 2 versions of pollen filters. A cheaper regular version and a more expensive charcoal version. I'm not sure if the regular one still exists or has been discontinued or what. However, I guess it doesn't really matter if you're used to driving with the top down all the time anyway.
Old 05-10-2005, 04:42 PM   #16
Perfectlap's Avatar
maybe its a mid engine thing.
Old 05-11-2005, 07:02 AM   #17
Thumper's Avatar
I picked up a new pollen filter off of eBay for $20
Thumper is offline   Reply With Quote
