Old 05-07-2005, 05:22 PM   #3
Brucelee
Brucelee's Avatar
Talking
Great stuff! We are intending to create a "how to" section with exactly this type of permanent posts. Thanks much!
One question-on the photo of the engine, I assume you are looking down through the opening right behind the rolll bars, correct? If so, can you describe how you got down there?
Also, I have found that a good vacuum with deep brushes will really get that pollen filter quite clean. I would NOT use that technique on the air filter but with the pollen filter, it will be fine.
Those pollen filters are very expensive, no?
Thanks again!
