Old 08-13-2010, 07:26 AM   #2
BYprodriver's Avatar
Only input I can offer is I have heard the fuel pump relays can go bad & a new one is $15 or less. It is easy to replace under the dash drivers side. Pull off the fuse panel cover & you should have a diagram there. I had to get a Bently manual since my diagram was missing. That may be the only problem.
