Old 07-06-2010, 10:25 AM   #1
Newbie question, throttle pedal
Hi everyone. I just put a down payment on a '99 boxster with low miles (48k). I test drove it and ran nice and had great handling. However, the throttle pedal was strange. The pedal felt normal for the first 1/3 of the range then it was very stiff for the rest of the range. It seemed to go to Wide open but I had had to press quite hard. After thinking it over I thought there must be something wrong with. It was just to stiff for comfort.
Anyone have any thoughts on this accel pedal situation. Is this normal?
johngault is offline   Reply With Quote
Old 07-06-2010, 11:00 AM   #2
ive never felt any strain in pushing the pedal. but mine is EGas so that may make a difference.
Old 07-06-2010, 11:13 AM   #3
landrovered's Avatar
There is no linkage, it is drive by wire, I suggest you replace the pedal with a new one, crap can get in the mechanism.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
Old 07-06-2010, 11:54 AM   #4
tonycarreon's Avatar
i believe '00 and later are actual linkage cables, and porsche switched to egas after that.
Old 07-06-2010, 12:09 PM   #5
My '99 is a linkage throttle, and there is no stiffness or strange feel to it. I'd get that looked at before you commit to buy if I were you.
I believe that egas was introduced in 2000.
Mark
'99 black 986
Old 07-06-2010, 12:49 PM   #6
Sorry I stand corrected I thought all 986s were egas.
Old 07-06-2010, 02:17 PM   #7
Mark
Thanks everyone. That is exactly what I need to hear. Great feedback!
Old 07-06-2010, 03:46 PM   #8
BYprodriver's Avatar
Boxsters had cable operated throttles until 2000MY when Porsche went to E-gas that opens the throttle electronically even though the gas pedal is connected by a short cable to the sensor that sends input to the ECM. Sounds like the OP's 99 may have a misrouted cable which should be a easy enough fix but makes you wonder if a major repair was being done & the cable was misrouted then. Could be a good thing (New Engine ) or amatuer maintenence.
