Old 05-27-2010, 04:01 AM   #1
Lowering Springs.
Hi guys,
I want to buy a set of H&R lowering springs for my car, as they the best out there?or are there other good brands too? Anything I need to know before making this mod? Know the H&R's drops the car by 30mm, it's my weekend car, so looking for something sportier looking aswell as something stiffer for my track days.
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
Old 05-27-2010, 06:04 AM   #2
you will also need Tarett rear toe links~480$. the explaination is long. search the forum. just trust me you will need them to get the car back into alignment.
The drive is so much tighter and smooth. little bumpy. makes the car look great
2002 S
jhandy is offline   Reply With Quote
Old 05-27-2010, 06:14 AM   #3
Send a message via AIM to 986rgt
I like my H&Rs
I just did H&Rs and Bilstien HD Struts. You can use the stock strut, but they wil not work as well, will wear out quicker since they are not designed to work with the new springs. I was able to get my car in spec for alignment, its at the very edge of spec, but I have not seen a bad result in tire wear or performance. Go for it, you will love the look, just watch out for speedbumps and entrances to parking lots etc.
Steve
986rgt is offline   Reply With Quote
Old 05-27-2010, 09:06 PM   #4
2001 RUF 3800S
violametallic-S-'s Avatar
I put Eibachs on mine - on the original struts. 1" drop, made a huge difference in apperance. No noticable uneven wear. Heres a pic...
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 05-27-2010, 09:53 PM   #5
If you are interested, I might be selling a very nice setup. Great for both street and track. 22-way externally adjustable rebound/compression (or maybe it was 23 way) OHLINs dampers, with Eibach springs.
OHLINS are top tier in the suspension game...
Not cheap, but if you want more info, let me know...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 05-27-2010, 11:57 PM   #6
lowering springs
Thanks for all the help so far, have a good idea of whats going on now...Have any of you fitted extended adjustable toe links to the rear when doing a lowered spring mod? And anyone had problems with getting the car back into wheel alinement?
