Old 05-14-2010, 07:20 AM   #12
I like the PF rotors since they're only dimpled which is way less likely to crack than cross-drilled rotors. I only found out after I received them that their hats are not made of aluminum due to lack of strength & restriction in size. I had them coated since they're not coated (bad for winter) as well.
I'll be doing some track with them on stock pads, and provide some feedback.
