Old 05-10-2010, 06:14 AM   #1
Power problem 2.5 1999 boxster
Power problem
I got my car back 4 weeks ago after undergoing head gasket replacement
Since then I have had a power problem which is more noticeable the harder i try to drive the car. Up to 2.5-3k rpm I see maybe 25% drop in power, from 3k – 5k maybe up to 40% power loss. I will not take it up any further as I am a bit worried?
There is no other visible or physical signs only holding back
Anyone help?
Jason
J60SON is offline   Reply With Quote
Old 05-10-2010, 06:54 AM   #2
double check cam timing and anything else that was touched from the head gasket change
check compression and compare numbers
FERRARIFRANK is offline   Reply With Quote
Old 05-10-2010, 07:11 AM   #3
The mechanic dealing with this is reputable but he is still not sure what it is, there are no faults showing on the readout?
