Power problem 2.5 1999 boxster
Power problem
I got my car back 4 weeks ago after undergoing head gasket replacement Since then I have had a power problem which is more noticeable the harder i try to drive the car. Up to 2.5-3k rpm I see maybe 25% drop in power, from 3k – 5k maybe up to 40% power loss. I will not take it up any further as I am a bit worried? There is no other visible or physical signs only holding back Anyone help? Jason |
double check cam timing and anything else that was touched from the head gasket change
check compression and compare numbers |
The mechanic dealing with this is reputable but he is still not sure what it is, there are no faults showing on the readout?
| All times are GMT -8. The time now is 01:19 PM. |
