05-01-2010, 10:45 PM
#1
Wheel Spacers Versus Performance
I want to do the infamous 15mm rear 7mm front spacers on my car.
Do wheel spacers negatively affect performance in any way?
Also will the car need an alignment after the change?
wouldn't the cars +/- Camber/Caster and +/- Toe In/Out remained unchanged?
I don't want to increase the rotational mass, so I assume the billet aircraft aluminum are relatively lightweight spacers.
Who makes quaility spacers? I was looking at Eibach. (hub centric)
anyone?
2003 Boxster S
05-02-2010, 09:33 AM
#2
I've had the 7/15 spacers on mine for three-four years. Eibach.(oops...just looked..H&R, not Eibach) No effect on alignment. There might/possibly/ could be a small increase in handling performance due to the slightly wider stance. The only real change is how they bring the tires out to fill the wheel wells. Much better look, imho.
Bob
79 911SC Targa.. gone but not forgotten
2001 Boxster Black/Savanah Beige
RoW M030 suspension
7/15 mm spacers
Deambered
Desnorked
SS door sills
Debadged
Clear tails
Technobrace
Technobra
I'll never own another black car!
05-02-2010, 12:02 PM
#3
anyone?
Assuming that all things are correct with regard to your alignment specs, adding spacers should have little or no impact on your current suspension set-up. FVD probably spikes a bad chord with you, however, for one price their spacers kits come complete with everything that you need ( i.e. correct length lug bolts, countersink screws ect..), and quality is excellent. In fact, I believe that they actually sources theirs from H&R.
05-02-2010, 03:38 PM
#4
I have no problem with the company if they supply a good product. Just looking quickly at the spacers they sell. They have the best price I could find, but there 7mm spacers are not hub centric like there 15mm. Is there still enough hub left sticking out for the front wheel to catch on, since its a fairly thin spacer????
H&R is way more expensive but advertises hub centric on both 7mm and 15mm.
2003 Boxster S
05-02-2010, 07:36 PM
#5
The FVD 7 mm spacers are definitely hubcentric, I have them on my vehicle. Perhaps, their site doesn't have a good photo of them, but they are definitely hubcentric. To answer your question, any spacer thicker than 5 mm has to be hubcentric.
05-02-2010, 08:53 PM
#6
I am doing 15s on the front and 20s on the back..........with 18" sport classics. Why 7s and 15s do you have a different wheel or is there a negative with sizes higher?
The car feels much more stabil, especially over ruts. I have a feeling that there is a roll centre change as well.......towards the longitudinal c of g give less of a roll moment.....can anyone confirm this?
05-03-2010, 12:31 AM
#7
I have 18 carrera lights.
I've never heard of going 15 and 20. seems a bit much. I don't have much knowledge in this area.
Also will this help run a wider rear tire. Like going from 265 to 275 or 285??
2003 Boxster S
07-24-2010, 04:34 PM
#8
Carnut
quoting
To answer your question, yes, enough left though just a bit.
BTW, my wheels/tires are the stock 17"
Took another drive today, all is good and the handling def improved!
07-24-2010, 06:29 PM
#9
Originally Posted by AndyA6
quoting
Looks good. not quite enough spaceage for me though. 23 rear 15 front will bring the tires completely flush with the fenders. Yours may handle better though. mine feels like the front is a little slower when turning. anyways mine will be for sale as soon as I can get pics up. Returning car to stock and selling it.
2003 Boxster S
05-03-2010, 10:39 PM
#10
I have used to max35.It was interesting.I assume that all things you have a correctly.But you have find negative wheel as you find and as you thought about it.But i have thought that you have suffer problem when you has run on long drive.But quality you have specified, It was so fantastics.
05-04-2010, 03:05 PM
#11
What the hell did he say?
05-04-2010, 03:18 PM
#12
15s and 20s make the wheels and tires I have flush with the body without contact and rubbing (negative camber on the rears make the bottom half come out). I would have thought this to be quite a common arrangement. Anybody else have 15s and 20s on the rear???
I would think if the offset value of the wider wheels you are considering is the same as the old then, you would gain room for them on the inside with spacers but I think the offset distance will surely change and you will end up rubbing. Also, as far as I know you would have to match/change the wheel size with any change in tire size
Spacers do give you the effect of wider tires and increased track width.....and seem to give a positive roll centre change making the car more sure-footed. Anybody have negative experiences??
Perhaps a wheel and tire expert could chime in????
05-04-2010, 03:49 PM
#13
I could not agree more. Well put.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
05-04-2010, 04:28 PM
#14
2K3 Boxster S...are you running the stock wheel widths/offsets? I run 8 & 10 X 18 and wouldn't have any room or need for spacers, as my wheels fill the fender wells already..
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
05-04-2010, 06:12 PM
#15
yep, i'm running stock 18". Carrera lights. the ones that were a factory option for the 2003. I don't even know how wide they are. 18x9 maybe????
Check this out. it's a Porsche bulletin for the Boxster. This is funny.
Non-OEM Wheels/Bolts [grp4 9701 4407 3/4/97] 1pg
Use of aftermarket wheels or wheel accessories (spacers etc.) or non-OEM wheel bolts on Boxster vehicles is not approved.
Only the standard wheel bolts can be used to securely mount the wheels to the vehicle. Boxster wheel bolts with rotating spherical collars are a special design and made from a correspondingly selected alloy for compatibility with standard wheels.
Endurance tests have shown that conventional, commercially available non-OEM bolts can loosen when the car is driven, even if they were installed and tightened to the specified torque.
Eighteen inch wheels are not approved for use on Boxsters. Use of eighteen inch wheels on Boxsters under severe conditions may result in structural failures of the body and/or suspension.
If you use spacer's you will die. sincerely Porsche. drive safe.
2003 Boxster S
05-06-2010, 09:10 PM
#16
the discussion got lost on this....anyone with a negative experience while using 15mm spacers on the front and 20s on the rears?
....yes an S is suppose to have wheel bearings that can take this...
| Thread Tools |
| Display Modes |
Hybrid Mode
