04-25-2010, 01:10 PM
#1
IMS article
The latest copy of Excellence magazine has a two part article (first part in this June issue, part two in July I suppose) concerning the M96 IMS failures and fixes by Tony Callas and Tom Prine. There will be input from Charles Navarro of LN and probably by Jake Raby in the July issue. Good to know the topic is still alive and more fixes etc. are on the way down the pike. Check them out.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
04-25-2010, 05:38 PM
#2
Allen,
What is the date is this issue so I can order a copy. Does This article give info on other fixes? As far as I know there is only L and N.
04-26-2010, 08:20 AM
#3
Engine Surgeon
Tony and Tom did a great job on the article with a ton of research going into it's composition. They made lots of contact with Charles and I and just a few minutes ago I did a quick review of the second part.
Should open people's eyes further, for sure.
US Patent 8,992,089 &
US Patent 9,416,697
04-26-2010, 08:43 AM
#4
Originally Posted by jaykay
Allen,
As per my message: JUNE issue has part 1 and I imagine JULY issue will have part two with the information you are interested in.
AKL
04-26-2010, 03:54 PM
#5
For what it's worth, this years Consumer Reports listed used Boxsters ('97 to present) as models to look for
04-26-2010, 04:42 PM
#6
look for... on the side of the road?
'01 Boxster S, 51k miles
'05 Mazda 6 Grand Touring Wagon
04-28-2010, 04:43 PM
#7
If its possible for something to be really funny and really not funny at the same time, this is it.
2004 550 SE #1081 of 1953 (sold)
1997 911 Targa (sold)
05-01-2010, 08:56 AM
#8
Thanks for the heads up.
I had a look at the article and found it to be excellent; very comprehensive and detailed with a good frame of reference....great job Charles and Jake! I dont know too much about the M96 and always had though I had a three chain set-up but I have five!!!(2000 3.2).
Which chain arrangement has been found to be superior? I would guess at the three, but there are certainly a lot of chain guides and tensioners if I recall the schematic correctly...
Reason: error
05-02-2010, 01:35 PM
#9
The article commented on the positive effect of high pressure loading on the IMS bearings due to elastohydrodynamic effect. First time I recall reading that.
IIRC the failures were thought to be more frequent in lightly driven cars. Maybe this explains why. Or maybe frequent track-type loading is required?
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
05-02-2010, 08:22 PM
#10
I would also assume that running at higher revs on the track, the oil pressure would also be much higher than driving on the road, which in turn would force the engine oil into (and out of) the sealed IMS bearing.
When I ran my Mazda MX-5 (Miata in the US) on the track with the engine above 6,000rpm, the oil pressure gauge registered 5 bar (70psi), while driving on the road @ at 3,500 rpm the gauge registered about 4 bar (56psi) - a signifcant increase at higher revs. I can't see the plastic / nitrile IMS bearing seals withstanding 70psi hot oil pressure for long without letting some flow-through occur.
Perhaps thats why Boxsters driven "as they were intended to be driven" have a longer lifespan than the mollycoddled cars.......
2001 MV Agusta F4.
05-03-2010, 10:28 PM
#11
I has read the article and I was stuck! But sometime it could be happened.It was high pressure on IMS bearing so it has fast oil pressure while driving on the road.So if you has to see long drive.It could be better for you.
05-04-2010, 04:56 PM
#12
Engine Surgeon
FYI- Oil is not delivered to the IMS bearing via pressure at all.. what causes the seal to break down and fail is high oil temperatures.
US Patent 9,416,697
05-04-2010, 05:40 PM
#13
Thank's Jake - you are correct.
I don't know what I was thinking about, must be the old age brain fade happening (again)
2001 MV Agusta F4.
