Old 04-19-2010, 11:17 AM   #1
Backfiring while engine is cold
I live in the Bay Area(so we're talking 40 degrees cold), and since my battery died (due to a month of vacation) a few weeks back, my car has not been driving well while the engine is cold. It is hesitating, keeping a low idle, and backfiring occasionally. From using the search function, I'm beginning to guess the MAF needs cleaning or replacing. Does anyone want to help a brotha out?
Jon
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
Oaktown 986 is offline   Reply With Quote
Old 04-19-2010, 01:02 PM   #2
is it fine when its hot ? do you have a scan tool ? no fast idle when cold ?
extanker is offline   Reply With Quote
Old 04-19-2010, 01:15 PM   #3
It is totally fine when it's hot. I do have a scan tool; it hasn't thrown a code in a couple months, but last time was a P0449 I believe, and it was O2 sensor-related. It's also thrown a Secondary Air Canister code once before.
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
Old 04-19-2010, 01:22 PM   #4
i,m not a po pro but the throttle body can/may have a system call idle air bypass this gives you fast idle...see if your scan tool can monitor its position when cold...they can get "coked up"
Old 04-19-2010, 01:29 PM   #5
the idle is too low when it's cold, not high; it feels similar to the feeling a car gets when it's catalytic converters have gone bad. It revs up to a certain point, then stops accelerating, backfires, then resumes accelerating.
Doesn't feel right; but it's not a problem when I let it warm up...
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
Old 04-19-2010, 01:37 PM   #6
but alls fine when hot...so i,m leaning [pun intended] toward being lean ...like no inrichment aka cold start injector [if ap] cold motors need to be a little more rich...old days using a choke
Old 04-19-2010, 01:43 PM   #7
jcb986's Avatar
You also may have a coil pack going bad.
Old Hippie Young Heart
Old 04-19-2010, 02:38 PM   #8
This I could see; last time I pulled plugs I had a bit of oil in there. I bought new O rings, tubes, and have now received them. Try this first?
Jon
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
Old 04-22-2010, 02:06 PM   #9
sup holmes ...fixed....?
Old 04-28-2010, 08:04 AM   #10
Negative, been too busy lately. Next weekend I'm going to get to work on it, and if that doesn't work, time to go to the Stealership. Any good rec's in the Bay Area of CA?
J
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
