Old 03-31-2010, 01:05 PM   #1
There is another consideration.
When I tossed all my stock hardware and went with headers, cat bypass, tuned exhaust etc., the interior temperature of the 'trunk' storage compartment went down noticeably. Can be a big deal when bringing a frozen pizza home! Seriously it did remove a lot of hardware that was up close and personal with the underside of that compartment, and reduced the heat.
Having said that - I'm going back to almost stock because the noise is just too much - can't even talk to a passenger.
Kevfra is offline   Reply With Quote
Old 03-31-2010, 01:59 PM   #2
The upside would be transporting a hot pizza from the local italian joint. It would be like a mobile hotplate.
I'm beginning to think that stock exhaust is the way to go.
I not interested in the exhaust being so loud that it is overwhelming. I was just looking for that throaty sound and loud ONLY when you get on it. I was also looking to increase horsepower without compromising the core performance................. I've now heard Fabspeed-Maxflow and Borla if any at all.
Is that reasonable or a waste of time?
Doc
docmorin is offline   Reply With Quote
Old 03-31-2010, 04:58 PM   #3
Johnny Danger's Avatar
How about a custom 9FF cat back exhaust, along with a set of custom M&M headers and HJS high flow cats. The total cost would be around 60K. Nigh on to 10K for the exhaust system, and the remaining 50K toward retaining a good divorce lawyer.
Old 03-31-2010, 07:12 PM   #4
JAAY's Avatar
Stock S-Muffler, headers, cat delete................
JAAY is offline   Reply With Quote
Old 03-31-2010, 09:50 PM   #5
Lightning's Avatar
If you don't want your car to turn the CEL on and "throw a code", I would keep the stock headers (on your car, the O2 sensors look at the catalytic converters that are on the headers) and maybe try "cat bypass pipes" to replace your secondary catalytic converter assemblies. That will up the volume without creating resonance.
Then if that's not loud enough, you could change the muffler out for one of the Dansk units (a Porsche OEM manufacturer, TUV certified, and due to the single chamber/cross-flow construction, no resonance). They sometimes come up on eBay. There is also an internal hack to make the stock muffler louder (search the forums).
If you replace the headers, then you will need to move the O2 sensors to the downstream "secondary" catalytic converters. Some also replace the secondary cats with "sport cats", which ups the sound a little more.
Most of these changes will probably not increase torque. Some may increase HP in the upper range...
Lightning Motorsports
http://www.LightningMotorsports.US
http://www.youtube.com/LightningMotrsprtsUS
Lightning is offline   Reply With Quote
Old 04-01-2010, 08:01 AM   #6
MN 986's Avatar
Doc
The mod to increase the sound of the OEM muffler is the 'Crios mod', and you will find it with a search. I did it a year ago and was happy with the difference, which I think was more at idle than higher RPM (maybe because the de-snorkled intake sound was louder than the exhaust at high RPM).
I still wanted a little more sound with no drone, and I prefer the twin tailpipe look vs. the OEM muffler on my 2002 2.7, so this spring I changed the OEM muffler for a FVD/Brombacher 'Sound version' muffler. It has a little more rumble than the Crios mod at idle, and more sound as the RPM increases, especially over 4kRPM. It is not much louder than OEM when cruising on the highway. Like the Dansk unit, it has the stamped look of the OEM muffler, which supposedly helps with drone. They claim a hp increase, but that is not why I bought it. I certainly did not detect any reduction in power, there is no drone, and it sounds and looks great.
I have been following this forum for a couple of years now, and it seems that opinions on mufflers/exhaust systems vary quite a bit.
Check out all the options, and good luck!
MN 986 is offline   Reply With Quote
