Old 03-29-2010, 05:23 PM   #1
Exhaust recomendations for an 01 Boxster S?
Hi everyone. I just purchased a 2001 Boxster S and I would love to hear recomendations on Exhaust systems for it. I'm looking for a throaty sound and a few extra HP would be welcomed.
Doc
docmorin is offline   Reply With Quote
Old 03-29-2010, 09:40 PM   #2
Steve Tinker's Avatar
Jake Raby's dyno says that the standard setup is VERY difficult to top.
But if its sound you want, including the dreaded 3000rpm drone, there's a hundred different views on this site......
Search for Pedro's Garage exhaust mod which is relatively cheap compared to some.
2001 MV Agusta F4.
Old 03-29-2010, 09:47 PM   #3
kyleturner2020's Avatar
Maxflo hands down.
kyleturner2020 is offline   Reply With Quote
Old 03-29-2010, 10:37 PM   #4
See my mods. Get them and you will be very happy!!!
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
jwade is offline   Reply With Quote
Old 03-30-2010, 02:54 AM   #5
It is true, the stock setup is hard to beat.
I have however changed the headers for some cheap Chinese ebay specials, exceptional for the price. I have also removed the catalysts and put 2" bypass pipes in their place.
More power? Maybe a little. Better sound? It is louder, more throaty and metallic like a Porsche should be, but without the drone like a ricer. This I attribute to the muffler remaining stock.
To be quite honest it was more trouble and cost than it was worth, for little benefit, but it was fun to tinker around with it.
Daniel R is offline   Reply With Quote
Old 03-30-2010, 05:11 AM   #6
landrovered's Avatar
I have headers, no cats and a modified stock muffler and I think it is the best setup for the money. I too would like a bit lower tone at low rpms but not at the cost of a droning exhaust. My current setup sounds stock until you put your foot in it and then it is plenty low and plenty loud.
2001 Boxster S 3.6L, Zeintop
Old 03-30-2010, 06:16 AM   #7
Best bang for the buck is the modified stock exhaust and secondary cat bypass pipes. You can find a local welder that can do the bypass conversion on the cheap and there are options for the cat pipes; I went with "like new" used Fabspeed pipes.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 03-30-2010, 05:07 PM   #8
Is there somewhere we can find this data? I've looked around and haven't been able to find his dyno results.
BudmanV24 is offline   Reply With Quote
Old 03-30-2010, 05:36 PM   #9
I doubt he has posted much on the subject
as all it will do is create controversy.
I will admit to talking to him while he was doing these tests ... he was looking for the best combination for a friend's car that would be both road and track. And he was expecting to find a brand he could recommend. His tests disqualified droning exhausts as they had to be driveable. He was surprised at the results of his tests as, of course, they contradicted all the advertising claims.
Your ears only have so many vibrations built into them .....
Old 03-30-2010, 06:13 PM   #10
Wink Thank you all for the responses
This gives me a starting point to research options. Any other ideas are welcomed!
Doc
Old 03-30-2010, 07:03 PM   #11
The dual canister FabSpeed setup (complete with secondary cat bypass pipes) sounds phenomenal with none of the dreaded drone just under 3000RPM.
Boxster S
Old 03-31-2010, 07:54 AM   #12
Thank you Sir
What did that run you?
Old 03-31-2010, 08:04 AM   #13
keep in mind that even if there is no gain in getting an aftermarket system you can also lose massive amounts of weight. and mixing the exhaust with a spare tire delete and you have lost yourself around 50 lbs in one fell swoop.
Old 03-31-2010, 10:11 AM   #14
Lil bastard's Avatar
Bear in mind that most aftermarket exhausts underperform the stock setup, despite their claims. And it is a rare exception which equals or betters the stock exhaust.
Switch to aftermarket and odds are that weight will not be the only thing you're losing.
Aftermarket exhausts in general are just not worth the hassle and expense on these cars. If you like to tinker, or are only after 'better' sound, that's a different story.
If you can't stand that hole burning in your pocket, suggest you throw the cash at something else rather than an exhaust.
'Course then, you can't brag that you have the 'Stainless Steel 'X'-Fab Triple-Speed Go-Fast part'... even if it isn't.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-31-2010, 10:12 AM   #15
That's helpful, thanks.
Doc
Old 03-31-2010, 01:05 PM   #16
There is another consideration.
When I tossed all my stock hardware and went with headers, cat bypass, tuned exhaust etc., the interior temperature of the 'trunk' storage compartment went down noticeably. Can be a big deal when bringing a frozen pizza home! Seriously it did remove a lot of hardware that was up close and personal with the underside of that compartment, and reduced the heat.
Having said that - I'm going back to almost stock because the noise is just too much - can't even talk to a passenger.
Kevfra is offline   Reply With Quote
Old 03-31-2010, 01:59 PM   #17
The upside would be transporting a hot pizza from the local italian joint. It would be like a mobile hotplate.
I'm beginning to think that stock exhaust is the way to go.
I not interested in the exhaust being so loud that it is overwhelming. I was just looking for that throaty sound and loud ONLY when you get on it. I was also looking to increase horsepower without compromising the core performance................. I've now heard Fabspeed-Maxflow and Borla if any at all.
Is that reasonable or a waste of time?
Doc
Old 03-31-2010, 04:58 PM   #18
Johnny Danger's Avatar
How about a custom 9FF cat back exhaust, along with a set of custom M&M headers and HJS high flow cats. The total cost would be around 60K. Nigh on to 10K for the exhaust system, and the remaining 50K toward retaining a good divorce lawyer.
Old 03-31-2010, 07:12 PM   #19
JAAY's Avatar
Stock S-Muffler, headers, cat delete................
Old 03-31-2010, 09:50 PM   #20
Lightning's Avatar
If you don't want your car to turn the CEL on and "throw a code", I would keep the stock headers (on your car, the O2 sensors look at the catalytic converters that are on the headers) and maybe try "cat bypass pipes" to replace your secondary catalytic converter assemblies. That will up the volume without creating resonance.
Then if that's not loud enough, you could change the muffler out for one of the Dansk units (a Porsche OEM manufacturer, TUV certified, and due to the single chamber/cross-flow construction, no resonance). They sometimes come up on eBay. There is also an internal hack to make the stock muffler louder (search the forums).
If you replace the headers, then you will need to move the O2 sensors to the downstream "secondary" catalytic converters. Some also replace the secondary cats with "sport cats", which ups the sound a little more.
Most of these changes will probably not increase torque. Some may increase HP in the upper range...
Lightning Motorsports
http://www.LightningMotorsports.US
http://www.youtube.com/LightningMotrsprtsUS
Lightning is offline   Reply With Quote
