Old 03-18-2010, 07:17 AM   #1
Hey Jake--need an opinion
here's a link to a Boxster with an engine noise; would appreciate a comment on what it sounds like to you.
thanks, Mike
http://www.youtube.com/watch?v=MPu-5FnTEcg&feature=email
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
MikenOH is offline   Reply With Quote
Old 03-18-2010, 04:23 PM   #2
BYprodriver's Avatar
thanks, Mike
I don't think that's a rod but I definetly wouldn't run the engine till you fix the problem.
Old 03-18-2010, 05:33 PM   #3
Track rat
Topless's Avatar
Lifter noise or worn timing chain tensioner is my guess. Either way shut her down.
Old 03-19-2010, 07:38 AM   #4
Engine Surgeon
Collapsed lifter.
But you know, those never happen according to lots of "forumites", so it must be something else.
US Patent 8,992,089 &
US Patent 9,416,697
Old 03-21-2010, 03:45 PM   #5
Hi Mike, is your car still under warranty?
What's your mileage? What oil? What oil change interval?
Thanks.
Old 03-23-2010, 05:49 AM   #6
I had a similar noise. Engine chain-like noise emanated from the water pump (Jake found it). Easy enough to remove belt and check shaft play.
Good luck.
jbox53 is offline   Reply With Quote
Old 03-23-2010, 07:11 AM   #7
The warranty expired in late nov 09; 23K; M1 every 5-6K.
Thanks.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 03-23-2010, 02:33 PM   #8
Engine Surgeon
Something added to the oil that cleans lifters will make the problem WORSE. The reason for this is the lifters only have ONE hole that allows oil to enter into them, oil does NOT pass through them.
So adding something to the oil that cleans the lifters simply washes the other debris in the engine into the lifters and tensioners.
If the lifters had two oil passages, and oil passed through them the additives may be effective.
US Patent 9,416,697
Old 03-24-2010, 07:53 AM   #9
Jake:
When you have inspected a collapsed lifter--was it due to foreign material clogging the lifter, bad lifter design, both?
Mike
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 03-24-2010, 09:40 AM   #10
Mike, I am confussed. The Boxster in the video is black. The car in your signiture line states Guards Red.
Is this your car in the video? Thanks.
Old 03-24-2010, 03:03 PM   #11
No, that is not my car; I have an 06 that was making the same noise as the one in the video, so I posted the link to see if I could get an opinion on what the problem might be.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 03-24-2010, 03:21 PM   #12
^OK, Mike. I understand better now.
Now, next question(s), "is" your car making this noise, or "was" it making this noise?
What does the print-out of the 6 Ignition Ranges look like on your DME? This would be very good to know.
Did you recently miss a shift? Spin the car? Bounce off the Rev Limiter?
