Old 04-20-2010, 07:55 PM   #1
Swap door speakers/lower panels from '00 to '03?
I've got a 2000 S model with door speakers, and I'm looking at purchasing an '03 that does not have door speakers. Anyone know if it's possible to swap them to the newer car? Does the entire door panel have to be swapped, or does the lower (carpeted) part come off separately? Sure like having the door speakers...
charcoal987 is offline   Reply With Quote
Old 04-21-2010, 09:27 AM   #2
The panel is all one piece. As far as the interchange between 2000 and 2003, I do not know.
2001 Seal Grey, 2.7L
drem914 is offline   Reply With Quote
Old 04-21-2010, 04:55 PM   #3
I would assume the panels would fit, but you'll obviously have to run the wiring.
Boxster S
Old 04-21-2010, 05:34 PM   #4
The metal door shell is the same part number for all 986's, and the 986's of 1998 and later vintage have side air bags, so it should be a direct replacement.
The panel is one solid piece.
Regards, Maurice.
schoir is offline   Reply With Quote
Old 04-21-2010, 05:57 PM   #5
Thanks everyone! If I do end up attempting the swap, I'll be sure to post on how it works out.
Old 04-21-2010, 06:17 PM   #6
Here is a link to a DIY that includes instructions on how to remove a Boxster door panel: http://www.bombaydigital.com/boxster/projects/window/
Regards, Maurice.
