Old 03-27-2005, 10:08 PM   #1
19's on a Box
19x? in the fron, 19x? in the rear, with what tire size?
In other words, how large can I go with stock height, without scraping...?
Morelli is offline   Reply With Quote
Old 03-27-2005, 10:41 PM   #2
1. For a safe bet, you can go with the sizes of the OEM optional 19" wheel/tire pkg. (assuming 986 and 987 have similar offsets)
2. As long as you have the correct offset, wheel/tire width and respective tire profile, you can fit 20" or larger. Remember, the overall diameter should not change or changes very little. Larger wheel is compensated by lower profile (sidewall) tire.
My humble opinion is that anything larger/wider than 18" 235/265 will only hurt the boxster's performance... unless you have some good reasons under the trunk that suggest otherwise.
No_Name is offline   Reply With Quote
Old 03-28-2005, 06:01 AM   #3
Brucelee's Avatar
What year are we talking about? We know that the 97 Box can't handle 17s.
What are you after in going to this size anyway?
Old 03-28-2005, 06:52 AM   #4
It's a 1999. I need a new tire, so I figure I should logically replace all four...and the rims they are on...you know...
Old 03-28-2005, 07:15 AM   #5
Brucelee's Avatar
You may want to stick to 18s and BTW-have you priced this all out? We are talking serious dough here!
Old 03-28-2005, 08:24 AM   #6
Yeah I know...it hurts, haha
Old 03-28-2005, 08:42 AM   #7
You may very well have ride/fitment issues if you try to go 19" on pre-05's. I wouldn't go any higher than 18's. I've seen 19's on a couple 986's and they tend over power the car and you start to get into 'bling"terrritory.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
