Old 02-19-2010, 10:01 AM   #1
97-99 "S" Brake Upgrade from Suncoast
Has anyone done this upgrade?
http://www.****************************************************.com/product/SbrakeKit.html?Category_Code=98625brakes
Simple enough in terms of labor.. and my front pads are shot. The rotors are getting a tad scored and I'm thinking that this may be necessary. Any thoughts?
J
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
Oaktown 986 is offline   Reply With Quote
Old 02-19-2010, 10:23 AM   #2
97 Boxster's Avatar
I liked this set as well. I have been thinking about doing it to my 97. Any advice from others or reviews on these would be appreciated.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 02-19-2010, 10:26 AM   #3
J
We have done several, including the four-wheel upgrade they used to offer as well. Kit is a bolt on swap that can be handled by just about anyone with a modicum of mechanical ability...............
Old 02-19-2010, 11:20 AM   #4
but is it worth is in terms of the extra $1k investment? I've done plenty of brakes, clutches, etc, in my time; i'm not worried about the difficulty.
I like the factory brakes, but I'm upgrading the power in my vehicle at the end of the year when i put her away for rainy season.. and i'm figuring i could either just do some standard brakes to get me through my next 20k miles, or upgrade...
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
Old 02-19-2010, 12:40 PM   #5
Your question is nearly impossible to answer; larger rotors and calipers will give you increased brake swept area, but how much of an adavange that would yeild depends upon the driver, how the car is driven, etc., etc........ We know for a fact that doing all four corners on a car with someone that knows how to drive and uses the car in Auto cross type events was a postive move; but for the "average Joe" on the street it probably wouldn't make much difference as the OEM setup was already pretty good. Also, be aware that using the "S" brakes requires larger rims, which can impact the attractiveness of the upgrade as well.......
Old 02-19-2010, 12:40 PM   #6
jcb986's Avatar
I have a 2000 S with a 3.2 liter. Replaced my brakes with new replacement rotors and pads...basically stock for about $350. If you're not into tracking and use your car for basic fun, seems like a steep $ to pay. After I bedded my brakes good and hard, this sucker stops terrific.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 02-19-2010, 02:09 PM   #7
I like the factory brakes, but I'm upgrading the power in my vehicle at the end of the year when i put her away for rainy season...
Depending on how much power you are adding, bigger brakes are either a good idea or a must.
My rule for upgrades is reliability 1st, handling 2nd, brakes 3rd, and more power last.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
Old 02-20-2010, 09:33 AM   #8
Lil bastard's Avatar
Originally Posted by 70Sixter
Depending on how much power you are adding, bigger brakes are either a good idea or a must...
Gotta disagree.
More power, in and of itself, is no justification for bigger brakes.
The car w/ base stock brakes stops from 60MPH in 111'. The same car w/ more power (assuming the weight stays the same) will stop in the same 111' from 60MPH - more power just gets you to 60MPH faster. And, there are very few other car models out there that can do this stop in 111' - stock base brakes are EXCELLENT!
The ONLY justification for bigger brakes is track use where fade is minimized due to better heat transfer because of the larger area of the rotor. This is beneficial because of the constant On/Off brake application with little time interval between applications to lose heat.
On a street car, where minutes pass between brake applications, fade is nonexistant. You spend $1400 and get 4' better stopping from 60MPH.
For a street car, in terms of cost/benefit, you may as well go out and buy 1400 Lotto tickets because there's a better chance you'll get something for your money which you actually can use.
The Big Brake pkg. is mostly a Bling thing for streeters.
Cheers!
1976 BMW 2002
1990 BMW 325is
(gone, but not forgotten)
Old 02-20-2010, 05:19 PM   #9
To re-quote Billy Crystal (SNL): It is better to Look good than to Drive good. And I look very, very Good.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 02-19-2010, 02:09 PM   #10
Porscheectomy
J
They don't mention brake proportioning. I'd think you'd want to rebalance the brakes if you're changing the diameter of just the fronts.
Old 02-19-2010, 03:34 PM   #11
No change is required for this type of upgrade.
Old 02-19-2010, 04:01 PM   #12
Track rat
Topless's Avatar
Forum member "insite" did this upgrade to his 99 and was very satisfied with the results. He was a track junkie and put them to the test. I don't know, I do a fair number of track days and have never run out of stopping power (except when I boiled some old brake fluid) and $1300 is about two sets of comp tires. I probably would do it if I mounted a 3.4L in there due to the higher corner entry speeds. For now I feel like the brakes are the best part of this car. Fresh fluid and quality pads and I am good to go.
Old 02-19-2010, 04:07 PM   #13
Porscheectomy
So do the S and non-S have the same proportioning valve PN?
Old 02-19-2010, 04:30 PM   #14
Without actually checking, I really do not know, but I suspect they do. What I do know is that we have installed several two and four wheel up grades, and none of them required the proportioning valve to be changed (the kits all came from Porsche). I have also worked on a couple of early cars that did the four wheel upgrade the hard way (swapping out the rear carriers with units from the bone yard) and neither had changed the master cylinder or proportioning valve either.
What I can tell you is that from 97-04, there are only two master cylinders for these cars: with or without stability management systems (PSM). The base and S car carry the same master cylinder....................
Old 02-20-2010, 05:50 AM   #15
Porscheectomy
I'd be really surprised if they were the same. Brake balancing is dependent on brake torque at the front/rear and weight distribution, which is different between brake designs and car models. Considering all the little "tweaks" that they make between models in the suspension because of weight balance, I'd think they'd do the same with brake balance.
It's not that you can't get away with proportioning that's off somewhat, it's just that the brakes are not as effective as they could be. In fact, it might never even be noticed especially with ABS keeping premature lockup from showing.
Adding more braking torque to the front wheels (bigger brakes, higher friction pads) will tend to lock them up sooner. So the proportioning should be shifted slightly rearward. Normally, a car is set up to lock up the fronts before the backs anyway to maintain stability, so upgrading just the fronts w/o the proportioning wouldn't change the car's balance but it wouldn't optimize the setup either. Upgrading the rears without the fronts, or significantly more than the fronts is when you'd start to run into problems with early ABS activation and a loss of stopping power.
