Old 07-16-2010, 06:49 AM   #21
Opposed to Subie Burble
Overdrive's Avatar
glad the car's mo' betta now, Randall. Seems I may be in the same boat as you should my lock(s) go out, and if it happens further down the road I may be paying even more of a premium. I too, have a model without side airbags.
I have to wonder how much weight would be saved without all the powered crap in the car? Of course, I know there's no model that is so base that it has manual windows and locks, but wouldn't mind it.
-O/D
IMSR + RMS
Robbins glass window top
Old 07-16-2010, 07:31 AM   #22
60-90 minutes tops if you have the right sized triple square tool for those bolts. Do sort that so you don't have to take vice grips to them.
You're on your own with the ignition switch though. I've not done it and brought it to my indy mechanic to do it for me. He had one in stock and swapped it in 45 minutes.
Old 07-16-2010, 08:01 AM   #23
97 Boxster's Avatar
Ignition Switch doesnt seem to bad its the lock crap that I was not looking forward too. I will keep you posted.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 07-16-2010, 08:15 AM   #24
actually, the ignition switch is a pain in the butt. You have to work upside down and use really tiny screwdrivers and yank out parts of your AC duct work.
The lock mechanism, if you purchase the right one for the 97's which is model year specific, is far easier to access although the door panel has to come off (5 minutes work if you've done it a bunch of times like I have).
Old 07-16-2010, 09:01 AM   #25
Ah the joys of owning a first model year. In '06 when I was looking to buy, I had my eyes on a "cherry" '97 with about 50k miles on it. I had negotiated a price with the Porsche dealership, but when I saw the long list of repairs that had been done (including several ignition switches), I backed out and waited until I found my '01.
At least you've got one of the collectibles!
Old 07-16-2010, 09:21 AM   #26
97 Boxster's Avatar
Randall,
Did you have to replace several clips when removing the door panel? Want to know if I need to get a handful of them in case they break.
Also looks like I need to figure out the Ignition Switch cause its going to happen more than once. It is an awkward position though.
Phoenix, Arizona
Old 07-16-2010, 09:43 AM   #27
97 Boxster's Avatar
Can find plenty of ignition switches, but that door lock mechanism seems to be like finding a unicorn. Pricing is crazy on those. Nobody with a wrecked 97 out there??
Phoenix, Arizona
Old 07-16-2010, 03:43 PM   #28
Order it from Sunset. Special order from the fatherland, but that's the route I took. I looked everywhere for a salvaged one and could not find it. :ah:
Old 07-17-2010, 04:22 PM   #29
97 Boxster's Avatar
Just an update (I will post pics later). I removed my door lock mechanism and wanted to see what this part was all about. Not to difficult to remove. Kind of an awkward position to fit your arms into the doors . Once I removed the mechanism I noticed that the spring was out of position so I used my pliers and put it into place (again, it will be in the photos) and lubed the necessary parts. Cleaned the mechanism and microswitches and re assembled and voila the door lock now works like a charm and the window drops as it should.
Seems like this may hold me over for a while (I will keep you updated on that one). I will order the ignition switch next week and install that next weekend.
Thanks to all for your advice and help.
Phoenix, Arizona
Old 07-17-2010, 05:17 PM   #30
It really bothers me that you just took it out, fiddled with it a bit and put it in and it works now. I didn't even think to do this!!!
I might have saved myself a couple of hundred bucks.
Old 07-17-2010, 05:32 PM   #31
97 Boxster's Avatar
I did spend quite a bit of time looking at how this thing works (or in my case how it didnt). I looked at the Bentley Manual and how it compared to my DLM (door lock mechanism) and in the manual it says that the spring needed to be in the proper position for the door to operate properly. That was a BIGGIE for me because this was not in the correct position on my DLM. I basically gave the part a full service job and hope that from here on out it works as it should. Glad I didnt just plunk down the $$ but I am sure someday I will have too.
As far as the ignition switch, I heard they are going to be scarce. Is this the case? I dont think so because so many cars use that same switch right?? This shop in Houston said you will only be able to get the switch in the future if you purchase the whole ignition mechanism not just the ignition switch.
All in all it was a great day and I am so glad my window and door are working. The bad about today is I washed, waxed and detailed my P Car and while taking my son to a b-day party it rained and washed that clean away.
Phoenix, Arizona
Old 07-20-2010, 07:40 PM   #32
97 Boxster's Avatar
DLM started acting up again tonight . I will take it apart tomorrow and see if the spring came unhooked again. Wish there was more available than just one source for these. These friggin things are expensive.
Anybody want to part with and early 97 DLM for a Boxster without airbags?? I thought not.
Who has found the cheapest source? I am guessing that all are from the same place and quality??
Phoenix, Arizona
Old 08-02-2010, 09:55 PM   #33
My mechanic is saying one of the door lock mechanisms is shot and that's causing the car to unlock. Evidently, when the timing is off between the two doors the alarm system unlocks the car thinking one door is open.
Sad part is that he quoted $250 for the friggin part plus labor! Sheesh. I do not have this kind of money to spend right now.
At any rate, he said he could diagnose it with a PST tool and I could bring the car to his place later this week or this weekend and he had the part in stock.
Just thought I'd report back on this thread for historical purposes for others to read in the years to come when it happens to them.
I have been reading up on your door lock issue before RandallNeighbour, how you have successfully addressed it and the advice others have generously given. In turn, I wanted to request help in figuring out what I should.
Car is a '98 Boxster with M535 option that experienced the water under seat occurrence. Replaced alarm control unit. Main issue is that the key remote control does not lock and unlock both doors. Also, the dash central lock button is not working. The driver's door can be locked using the key but even when locking the driver's door with the key, the passenger door remains unlocked. The remote is however able to open the rear trunk and the red LED on dash blinks when the remote is pressed. So it appears that the key remote is able to send signals.
Curiously, when the key remote control is pressed, the gas cap door pin actuates to lock but almost immediately retracts (and the gas cap actuator makes a buzzing sound in the process) so gas cap door is also always unlocked (even when manually locking the driver's door with the key, you hear a buzzing sound from the gas cap door actuator, and the gas cap door remains unlocked).
The windows drop down a few inches when the outside and inside door handles are used. Even with the emergency three times manual turn of the key on the driver's door, the passenger door remains unlocked.
Durametric shows the following alarm faults:
46:
Control locking synchronization
Status: present
Occurance Counter: 1
10:
Voltage failure at terminal 30 with alarm system active
Status: not present
This fault is displayed for informational purposes, it is not an indication of a problem and no repair is needed.
47:
Status: not present
Occurance Counter: 13
25:
W lead
Status: not present
21:
W lead (DME immobilizer)
Status: not present
33:
Interior sensor faulty
Status: not present
Occurance Counter: 14
23:
W lead
Status: not present
Occurance Counter: 31
Thank you so much in advance for all your help.
prsch1 is offline   Reply With Quote
Old 08-03-2010, 07:43 AM   #34
I've no idea what all those codes mean nor did I hook up my boxster to an ODB tool.
What you are describing though is a bad door lock mechanism in the passenger side just as I had. When it could not lock the door, it sprang back into unlocked mode.
You are in luck though. The 98's through the 03's use the same part number and you should be able to get a passenger door lock assembly cheap and they will be plentiful.
You can take off the door panel and pop it out in under two hours if you are willing to give it a try. The only difficult part is finding the correct bit for the bolts on the exterior of the door that hold the mechanism in place. I bought a rather expensive 12-point bit set from Sears to do the job and it still didn't break the seal on the bolts they were so tight and I ended up stripping out one or two of them. Vice grips on the edge of the bolt does work though but you'll need touch-up paint afterwards if you are as anal as I am about my car.
Start contacting salvage yards.
Old 08-03-2010, 07:39 PM   #35
97 Boxster's Avatar
Randall is correct with all his information. You are lucky you have an newer model. You could call anybody and find what you need. The Door Lock Mechanism is what you need though. Good luck and its not too hard to DIY it but you do need long fingers or a skinny arm to do the trick. Patience will not hurt either.
Phoenix, Arizona
Old 08-11-2010, 08:02 PM   #36
Update
Thanks for all your guidance. Through the encouragement and assistance of Randall Neighbour and Boxster 97, I was able to remove the door panel and replace the passenger side Door Lock Mechanism (thankfully, as you pointed out, it is for the later than 97 model so they are more readily available and in abundance).
I am happy to report that the used passenger Door Lock Mechanism I bought now enables me to lock the passenger side door when I use the manual key lock on the drivers side (unlike before). Yet, three issues remain:
1. Still not able to close the doors with the central locking button on the dash.
2. The driver's side door can only be locked and unlocked using the manual key and does not respond to the key remote control. If I use the key remote the passenger door and fuel door actuator locks momentarily and unlocks right up again (makes me think that the driver's side lock is not allowing it to lock). If I first lock the driver's side door with the manual key lock, both driver's and passenger are locked. But when I unlock the doors with the key remote, the passenger's side door unlocks (without any issue) but the driver's door stay locked (and can only be unlocked by using the manual key). Does this also suggest a defective driver's side Door Lock Mechanism?
3. Also, when I use the passenger side outside door handle, the window drops only slightly (and not fully - not enough to clear the roof top seal when closing the door) so windows bangs against the roof top seal) afraid it might break the window glass. Does this suggest a defective microswitch inside Door Lock Mechanism?
Incidentally, lastly, when I lock the doors, there is buzzing sound at the fuel door actuator (did you have the same symptoms before and does this mean a defective fuel door actuator too?)
Again, thank you in advance for all your help.
Old 08-12-2010, 04:35 AM   #37
Sounds like you still have a locking issue, but the window not dropping enough to clear the tab on the top is a worn out regulator on that side of the car.
You may need to get the car hooked up to a PST tool at a dealer or indy repair shop to diagnose this locking issue.
Old 08-13-2010, 11:37 AM   #38
97 Boxster's Avatar
Hmmm. I agree with Randall. It sounds like you have done everything to solve the problem that you can do.
I had issues with mine a few weeks ago and so I took the door lock out of the drivers door and looked at it for anything I could see out of line. These mechanisms are too well sealed up to inspect for any breakage so I ordered a new part.
Well, guess what? That part came yesterday and I spent the evening out in my garage taking the door off and replacing it with the new part. This should have only taken 30 minutes or so but when I put the new part in ...... ta da - It didnt work at all. No response from the window at all and the door was not locking like it should. I tried resetting the windows and following the Bentley manual but no luck. I took it out and compared it to the old one and there were a few things that looked a little different but nothing major. When I say a little different, I mean some of the markings were not the same and stuff like that.
So I put the new one back in again. Keep in mind that you have to hook everything back up to make sure the door handle in and out work right?? Still not working. At least my old unit would work on occasion. This new one was not working with the locks or the window drop at all.
So I looked at the original unit and put it back in and guess what???? Door lock and windows all work like they should. I wonder now if it is a microswitch in the convertible top? Could that be a possibility??
Anyways that is why it took me all night and now I have an extra door lock mechanism. I will keep it for later. I know someday I will need it.
Phoenix, Arizona
Old 08-13-2010, 04:10 PM   #39
97 Boxster's Avatar
Update Update
Well, I shouldnt have jinxed myself. My door locks/window drop worked last night and this morning on the way to work. Even once I got to work the door window drop and locks worked as they should.
After work I went to get into the car and it wouldnt unlock both doors. The key in the lock just turned without resistance and when I opened the door the alarm went crazy. The window did not drop either.
This is too crazy. Has to be a short or bad connection somewhere is all i can figure. Can anybody shed any light on this?? Before you comment read my earlier post today to see what I already have done.
I want to tackle this tomorrow morning so any response is appreciated.
Phoenix, Arizona
Old 08-13-2010, 05:51 PM   #40
hi boxster 97, i truly appreciate your response and certainly hope I did not do anything to cause cause you any concerns. i actually felt better when i received your initial post as i exactly experienced the same thing - working the whole evening on the car - trying to determine what may be amiss.
i would defer to the experts on the board, but for what it is worth, from what i have learned first hand so far from working on the car and what i gather from the forums (and again the experts may know better), when turning the key and you feel no resistance, it could be a loose connecting rod between the physical lock and the lock mechanism - believe it can work itself loose and you check it by removing the door panel.
On the alarm, as I understand it (again the experts may determine otherwise) if you unlock the car with the key you have to place the key in the ignition within several seconds or the alarm will go off (I am not sure if your alarm went off right away when you used the key but it is possible because presumably you locked the door with the remote).
On the doors, from my experience, if one of the doors/door mechanisms is amiss, it affects the other one so if one is amiss, it may affect the other door as well.
On the window drop down, I understand there is an inside door handle microswitch (which may be bad if window does not drop when opening the door from the inside); an outside door handle microswitch (which may be bad when window does not drop when opening the door from the outside); a door larch mechanism microswitch (which may be bad when the window raises back up when either door handle is released) and a convertible top latch microswitch (which may be bad when both windows do not drop when using the convertible top).
I continue to work on mine, and will let you know if I determine anything that may be useful to you. Please let me know as well.
