Old 01-06-2010, 03:28 PM   #1
JMP
Headlight Assembly Gasket
Does anyone know if the gasket that surrounds the headlight assembly on a 99 Boxster is available and if so the part numbers or source that sells them. Thank you.
JMP is offline   Reply With Quote
Old 01-06-2010, 05:57 PM   #2
schnellman's Avatar
Suncoast
Unless someone comes up with a hot idea quickly, I'd call Suncoast parts at 877-923-1700 and ask them. They've always been able to help me out.
Old 01-11-2010, 02:49 PM   #3
I'm in the same spot you're in and the bad news is that the headlight seals are not sold separately. So when that $10 piece of rubber rots away after ten years like mine did, the nice fella at the dealership says "Sorry, ya gotta buy a new headlight for $1600US" Now, Pelican has the assemblies for somewhere around $400, but even that's a bit much just to get a gasket.
Right now I'm trying to source some good used ones through a wrecker. I've emailed just about every Porsche disassembler on the web and so far they don't have 'em, or won't sell 'em separatey from the lights, or just didn't bother to respond at all. I think about the only way I'll find them is if I locate someone with smashed headlights that still have good seals.
Good luck! Let me know if you locate someone with a stash of them!
Mark
Old 01-11-2010, 04:18 PM   #4
JMP
Headlamp Gasket
Thanks to everyone for your help. I have not found anyone that sells them but I think they are really more of a cosmetic item than a real gasket as water will just drain out through the bottom of the headlight pan anyway. Mine are getting kind of "gooey" and need replacing but I am not going to buy headlights just for this. I think a black caulk or weatherstrip adhesive might work and not look too bad if done with care.
Old 01-29-2010, 07:59 PM   #5
I found a source in Canada for these seals, if you're still looking:
http://www.nineapart.com/
Old 05-23-2016, 03:29 PM   #6
texomawaves's Avatar
I have the same goo-ey headlight gasket. Has anyone improvised something?
texomawaves is offline   Reply With Quote
Old 05-23-2016, 05:37 PM   #7
911monty's Avatar
I did the Steele rubber fix in the attached thread. While not stock, it is light years better than the gooey mess my gaskets were turning into. Actually looks pretty good.
Thanks to Spinnaker!
headlight trim for boxster 1998
