Old 12-30-2009, 06:15 AM   #1
The best performance modification that I have made to my Boxster-S to date!
I was researching the web and read the write up on Pedro’s garage about his Techno Torque2. I recall another article that I read earlier this year in one of the European Automobile magazines about the Cayman-S with IPD plenum and sport exhaust upgrade. So after Googling a bit more I found several IPD plenum kits for the 911’s, Boxster (3.4L), and Caymans but not for Boxster 3.2L. So I found the phone number for Mike at IPD, he is the designer/developer and had a good conversation about his 3.2L solution. He eMailed me back with his new 3.2L setup that he recently developed for a customer in England for his 2001 Boxster-S.
This setup includes an upgraded throttle body from 75mm to 80mm and a 3.4L Cayman-S IPD plenum with huge silicon hoses to replace the restricted factory intake hose. I believe it is all about the science of air flow, the bigger throttle body and the large silicon hoses get more air in and then through a larger plenum with Mike’s patented design to get the air flow distributed evenly and quicker to each bank. The result is lots of torque, and you can feel it more than any other modification that you may have made to your car (of course except for putting turbo or super charger kit).
Here are my existing modifications before IPD upgrade:
  • EVO cold air intake
  • Competition headers (no cats)
  • By pass pipes
  • - FVD sport muffler (the best damn muffler in the market, I had them all before this one; best sound, best performance)
  • ECU upgrade
  • PSS9 shocks
The installation was very easy and you can do it within one hour and it is all plug and play. After the install, the first thing you notice that the car will not struggle to rev up from 4000 to 7000 RPM and the power comes fast and it keeps going faster. Before the IPD upgrade, above 4800 RPM, I felt the car was running out of breath. Now it does not. Also, there is more torque than before, you notice this when you shift the gears and the rear of the car deeps more even with my PSS9 suspension. The last piece which was icing on the cake is the improved fuel economy. I am getting 2+ mpg more on the highway with the IPD setup than before. I measure my mpg regularly on the highway. I am planning to dyno the car next week and will post the results.
I have some great pictures for you to see the difference between standard equipment and the IPD setup for 3.2L. If you are interested let me know and I hook you up with Mike at IPD. I am not sure if he has the 3.2L kit distributed to his dealer network yet. There are several distributors that sell IPD gear. You can contact me at kias@tampabay.rr.com.
MetBlack-S
Factory side skirts
18" Sport Classic
B&M short shifter
IPD Cayman-S Plenum
80mm Throttle Body
FVD Sport Muffler
Fabspeed catbypass
EVO Intake
PSS9
Light flywheel and Sach stage II clutch
Front/Rear Strut Brace
Undetectable K40/3
Rear Defuser
Rear spoiler
kias@tampabay.rr.com is offline   Reply With Quote
Old 12-30-2009, 09:22 AM   #2
dalealan2001
Posts: n/a
Great info. How much did the kit cost? How long did it take to install?
Old 12-30-2009, 09:40 AM   #3
Very interesting write-up. Seems providing more air could be a good thing, as long as the ECU knows what to do with it and you have an exhaust that lets the air flow through the system.
Any experts out there that wish to comment? Has Jake Raby tried the larger plenum on his engines?
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 12-30-2009, 10:48 AM   #4
Topless's Avatar
Good points jmatta,
I am certainly no expert. Just an old hot-rodder who has tuned a lot of cars and bikes. In my experience tuning an intake is a balance between air volume, air velocity, and intake resonant frequency. If you get these things right you are rewarded with faster lap times.
Also you need to consider your goals. A 1/4 mile car may want to maximize hp near redline to improve top speed through the trap. A road race car may choose to maximize a wide torque curve for better corner exit speed. These two intakes would probably look very different. Bigger isn't always better depending on your end goals.
The IPD plenum and the Pedro Techno-torque are interesting because they appear to improve intake velocity. Any time you can reduce or eliminate flat surfaces or right angles tends to improve velocity. The proof is found in measurable results. Improved dyno curves are good, faster lap times are better.
Would I use one on my car ? Nope. I compete in a spec class which requires stock intakes. But I do find these designs interesting.
Old 12-30-2009, 11:02 AM   #5
The stock ECU will adjust for the changes within the first 50 miles or so. No need to remap the ECU for this modification.
MetBlack-S
Factory side skirts
18" Sport Classic
B&M short shifter
IPD Cayman-S Plenum
80mm Throttle Body
FVD Sport Muffler
Fabspeed catbypass
EVO Intake
PSS9
Undetectable K40/3
Rear Defuser
Rear spoiler
Old 12-30-2009, 11:18 AM   #6
If you guys interested, just eMail: sales@roadsportsupply.com
He has 2.7L and 3.2L kits for Boxster.
MetBlack-S
Factory side skirts
18" Sport Classic
B&M short shifter
IPD Cayman-S Plenum
80mm Throttle Body
FVD Sport Muffler
Fabspeed catbypass
EVO Intake
PSS9
Undetectable K40/3
Rear Defuser
Rear spoiler
Old 01-01-2010, 11:04 AM   #7
Check their dyno vid...
http://www.youtube.com/watch?v=vFmLlwKD69w
mebiuspower is offline   Reply With Quote
Old 01-01-2010, 01:00 PM   #8
Originally Posted by mebiuspower
Does not “prove” anything; made by the manufacturer/distributor and makes claims for 20+ HP increase at the rear wheels. Another dyno test, done by a magazine (assumed to be independent) finds less than half the power increase claimed by the manufacturer/distributor, sees most of it at the extreme RPM’s, and only in combination with multiple other modifications.
With minimal HP or torque improvements, if any, within normal driving RPM, and at a cost of somewhere between $70-140 per gained HP; you are paying a lot for small performance increases in engine speed ranges your car will see less than 1-2% of the time.
Very questionable…………………
