Old 10-16-2009, 02:17 PM   #1
JAAY's Avatar
160 Thermostat on order!
Just thought I would let ya'll know that I ordered a 160 stat from LN. Useless post.
Hopefully there in stock being that I have to change my coolant and though why waste the opportunity to mod some more....
Old 10-16-2009, 02:30 PM   #2
Welcome to the club...
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 10-16-2009, 02:41 PM   #3
Allen K. Littlefield's Avatar
Did the same when I had the coolant changed after my cap failure last summer. So far needle reads lower than with the stock thermo. Haven't really been on a trip on a warm day to really challenge it but it the needle does read lower. Seems like ever since I had it installed my section of the globe has significantly cooled, go figure!
Along these mod lines, I recently picked up copy # 185 of the UK publication, "911 & Porsche World" and it has a nice review of the larger capacity oil sump which helps hard cornering cars from oil starving on long fast corners. Nice photo essay as installed by Autofarm. LNEngineering along with Jake Raby carry the kit.
AKL
Old 10-17-2009, 06:50 PM   #4
I actually am considering the mod during the winter break. Can you (and anyone who has installed it) just give us an idea on what it takes to install it and how muc time it takes?
Michael
Michael
http://imgur.com/aiZcIk8
986FortyEight is offline   Reply With Quote
Old 10-17-2009, 06:57 PM   #5
Engine Surgeon
Michael
The low temp unit takes the same time to install as a stock T-stat.
I install one in every engine I build and I have one in both my test cars.
Look for an install DVD for the unit around Christmas...
Old 10-17-2009, 09:33 PM   #6
what are the benefits to the improved stat
Old 10-17-2009, 09:37 PM   #7
Jaxonalden's Avatar
...and the reason for installing a 160 degree thermostat? The factory one is set to high causing overheat problems? (Mines rock solid at 184). Fooling the computer that the engine is cold so it enriches the fuel? Old one doesn't flow enough coolant? Or is the oil temp to high and the lower temp thermostat will save the oils viscosity?
I'd love to hear the theory behind it.
Old 10-17-2009, 11:42 PM   #8
im under the impression ur not a fan of the LN stat?
Old 10-18-2009, 08:04 AM   #9
Jaxonalden's Avatar
Did you read my post? LN does great research and development to right the wrongs that our dear OEM did not and will not. I just want to understand the principal behind it.
Think of it like politics, I'm not going to act like a sheep because of what someone says, I want to know the background, path and if it makes sense.
cnavarro, thanks for the explanation. It does have merit.
Old 10-18-2009, 05:58 AM   #10
Although this has been covered many times, the low temperature thermostat doesn't trick the engine into warm up enrichment. Remember, if the engine doesn't go out of warm up enrichment in a certain window, it triggers a CEL. The DME is always adapting to hit it's target air/fuel ratios. Just because the coolant temp is lower doesn't mean it's going to run richer, it will run the same AFR! A cooler engine increases volumetric efficiency and more timing can be run safely, again timing being a variable that the engine can adjust.
The simplest answer for a low temperature thermostat is that other Porsche models have them and Porsche has been migrating to lower thermostat temperatures over the last few years on all their models. Just because Porsche did it, doesn't mean it's perfect or right.
Reducing the coolant temperature will reduce oil (and ATF, in tip cars) temperatures, which run 10-15F higher than the coolant temp in normal driving. If that was the only gain, that would be plenty in my book. Other benefits and general principals have been discussed in earlier threads.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
cnavarro is offline   Reply With Quote
Old 10-18-2009, 06:09 AM   #11
We already know that the casting alloys used by Porsche for the M96 are suspect and do suffer from cracking and failures. A simple 15-25F degree reduction in temperature can translate into an increase of several thousand psi of the tensile strength of an aluminum alloy. There are areas of the engine much hotter than what the temperature gauge indicates. Depending on the alloy, you can lose an additional 30 to 50% tensile strength from 212F to 300F.
Charles Navarro
