Old 06-19-2009, 01:29 PM   #1
MAF Sensor Typical Voltage Outputs
To add to the hundreds (?) of MAF-related posts...
I've searched pretty thoroughly, and I've been unable to locate anyone listing typical output voltages for a correctly functioning MAF. I've gotten a few random codes over the last few weeks that make it sound very likely that I need a new MAF sensor, but I'd love to be able to put a voltmeter on the actual sensor output and confirm this.
Anyone have a source? Or values?
-Michael
1999 Black/tan
machone is offline   Reply With Quote
Old 06-19-2009, 03:34 PM   #2
Connect voltmeter to pin III/23 and ground.
Switch on the ignition.
Display: 0.9 to 1.1 V
Start engine.
Display: approx. 1.4 V
funkdefino is offline   Reply With Quote
Old 06-20-2009, 11:43 AM   #3
Pin info?
Thanks for the quick response.
A little research shows that there are 5 pins on the MAF connector - is Pin III labeled as such?
Out to the garage to rig up something that will slide into the connector and connect to my multimeter and still allow it to connect...
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
