Old 06-08-2009, 04:31 PM   #1
HELPPP!!!!??? Engine Cooling Problem.
Hey guys, this is somewhat scaring me and before I bring it into the stealership I want to see if i can fix the problem myself.
Background: Last summer my car blew the "transcoolant valve" (regulates the flow of coolant into and out of the engine. It was towed to The Porsche Exchange in Highland Park, IL. They fixed it and pressure checked the system blowing my water pump... total bill cost me $1700+ $200 towing.
Now: The engine goes from average running temperature then goes up into the redline above 250 degrees... and will come back down if i turn the Heater on full blast. The cooling fan is running at full blast constantly saying the system is overheating and it is blowing out some coolant here and there because it is so hot... but its not staying in the redline, the temp will drop from red to under the 2nd white line to normal temps then back up.. and down... Now on the expressway for the most part it was stayin within Normal operation except for one or 2 times in a 30 mile round trip on the expressway.
Any clue as to what it might be? I dont want to blow the engine (143k miles on it) and I dont want to drop another $2k into the cooling system that has been recently worked on and replaced. Ohh btw, all my fluids are fine. Oil, gas, and coolant.
Thanks,
Adam
PlayersExpress is offline   Reply With Quote
Old 06-08-2009, 05:07 PM   #2
fluids are full and fine.. there is no error code going off, and no check engine or any other warning lights.
Old 06-08-2009, 05:52 PM   #3
Could be several things:
  • water pump,
  • gunk/clogs in the system reducing coolant flow through radiators,
  • junk clogging the air flow through the radiators, and/or
  • air bubble in the system.
Start with bleeding air out of the system & cleaning the radiators, then go from there.
Good luck.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 06-09-2009, 07:02 PM   #4
Brad Roberts's Avatar
You are explaining an air bubble in the system
Want to do this on your own? I can walk you through it
B
Old 06-09-2009, 09:32 PM   #5
Brad, that would be amazing if you could...! Ohh and if you ever get past the mock up stage with the V8 in the tub and want to actually try it on a car.. you know where to find me.
Im looking to not blow this engine if i can help it for about another 6-8months.. at which point im going to start my conversion to a bigger motor, possibly with forced induction.
Thanks a million!
Adam
Old 06-10-2009, 07:21 AM   #6
With the car COLD!
1. Open the rear trunk
2. Pull off the oil and coolant cap
3. With a small screw driver, pry underneath the "false floor" under those two caps and remove it completely.
4. Flip up the small bent steel wire on the coolant expansion tank pressure relief. It is located directly behind the coolant fill hole.
5. Put the OIL cap back on
6. Make note of the coolant level. Full should be just where the white plastic meets the black plastic. You can see where the two come together by looking inside the coolant fill hole. Top it off.
6. Install the coolant cap
7. Start the car and let it run for 5 min. Let it idle.
8. Keep an eye on the coolant reservoir.
9. Now, REV the engine to 3k and HOLD it there for 15sec.
10. Let it idle again
11. Repeat step 9
12. Let it idle again
13. Repeat step 9
14. Let it idle
15. Check the coolant level. DO NOT remove the cap!!
16. Drive the car around the block.
17. After returning, check the coolant level again
18. Let the car cool down (hour or so)
19. Top off coolant (it should be down) and it may be down earlier in this cycle
20. Drive around a few days with the steel wire to the coolant expansion cap in the UP position.
21. Keep checking the level while the wire is in the up position.
Side note: we run with the wire UP everywhere ALL the time. This is how we do it in Cup cars and this is how we do it in the Boxsters/Caymans. It gurantees that the system has no air bubbles in it. When you are confident that the issue has gone away.. flip the wire down and put the false floor back in
Or don't and run around with the wire in the up position. Let me know if you want pics. I can shoot some today while I do an engine pull and install.
B
