Old 05-20-2009, 01:45 PM   #1
997 C2 wheels on a 986 Porsche Boxster Base Model
I have a set of staggered OEM Porsche 18" 997 C2 wheels I'd like to fit on my 2000 Porsche Boxster (base model)
The stats on the OEM 997 C2 wheels are as follows:
Front Wheel Size: 18x7.5 225/40
Rear Wheel Size: 18x10 265/35
FRONT WHEELS OFFSET: ET50
REAR WHEELS OFFSET: ET65
As I understand it, I will need a set of 17MM spacer and longer studs for the rear wheels and they will bolt right on and clear all suspension components and not stick out too far that they rub or hit the cars fenders??
Am I correct in assuming the front wheels will not need spacers and will bolt right on without any additional fuss.
can I please get confirmation before I pull the trigger and make the buy?
2000PorscheBoxster is offline   Reply With Quote
Old 05-20-2009, 01:50 PM   #2
forgot to clarify, on the rear rims, with a 17mm spacer on the ET65 that'll give me an adjusted ET of 48MM
is et48 enough to clear the suspension components on a 2000 porsche boxster base model?
Old 05-20-2009, 05:30 PM   #3
Bump!Bump!Bump!
Old 05-20-2009, 05:48 PM   #4
If you wind up at ET48 on the rears with a 10" rim you should be just about perfect.
Boxster S
Old 05-20-2009, 07:04 PM   #5
thanks for the input patrick!
can you speak to the tire clearance re: the fender?
265/35 on a 10" rim with et 65 and 17mm spacers?
Old 05-20-2009, 07:08 PM   #6
this may be a dumb question, but i assume you torque the studs to the same spec with or without spacers? 96 ft/lbs
Old 05-20-2009, 07:33 PM   #7
Porsche "Purist"
Paul's Avatar
That's what I use on my 996 18s on my 986.
1987 924S. 2002 996TT. PST-2
Old 05-20-2009, 09:42 PM   #8
On a 265/35 you'll be just fine.
Boxster S
Old 05-21-2009, 06:30 PM   #9
s-u-c-c-e-s-s
that's the way you spell success!!
et65 + 17mm spacers on 18x10 rims = perfect
265 rubber = beefy!!
