Old 04-27-2009, 09:08 PM   #1
Replacing Front Motor Mount, OEM or Pedros?
It looks as if I'm going to be replacing the motor mount, looked over the DIY and it looks pretty straight forward. I do not regularly do DE or AutoCrosses, I may fit one or two in an the next year or two. My question: Is the OEM unit a safer bet (there sure seem to be alot of them failing per these boards) for my type driving or is the Pedro's Enthusiast model more stout without being too harsh? Thanks in advance.....Mark.
Old 04-27-2009, 09:34 PM   #2
I have the Enthusiast mount, and I am happy with it. Installation is a bit more of a ********************, as it has much less play. This also causes a bit more engine "feel" to be transmitted into the cabin. It does improve shift quality, and hypothetically should be longer lasting.
Boxster S
Old 04-28-2009, 04:31 AM   #3
This one is great for racing, but really vibrates at idle and low speed. It shows how much the stock mount gives, as the back end of the car really feels a lot more solid with this mount in.
But I use this one for my daily car, and it feels the same as stock, but is much stiffer.
I have been throwing the idea around of adding / changing some of the mount locations; as I think that the engine moves too much, which preloads one rear tire more than the other (not good since we don't have LSD's stock).
cheetah is offline   Reply With Quote
Old 04-28-2009, 08:00 AM   #4
Thanks for the responses. Just ordered the Enthusiat's Mount from Pedro, spoke to him on the phone, heckuva nice fellow.
Old 04-28-2009, 11:54 AM   #5
is there any way to know if/when to change this w/out physically looking at it?
is there any tell tale sign that the mount is worn/loose/broken?
is the change in shift feel, etc noticeable if your stock mount is intact - or is the change more due to the new mount being stiffer - so that even going from a good stock one to the enthusiast mount would produce a noticeable improvement?
is this a good "bang for the buck" mod?
what exactly do you notice after installing it that is "better" than before?
23109VC is offline   Reply With Quote
Old 04-28-2009, 12:49 PM   #6
Many people are probably driving around with a broken mount and don't even realize it. It "feels" more solid and stable when replaced. Hard to explain.
Mine looked like this:
The engine and trans are not supported on the sides very well, so this front mount takes a lot of twisting abuse.
I think that no matter which route one takes, replacing it is a real good idea (especially if the car is driven hard).
Old 04-28-2009, 01:20 PM   #7
I noticed a little more sloppiness to the clutch take-up / engagement. Hard shifts and aggressive driving resulted in the occassional "cradle thump" that I've had occur in other cars and I knew exactly what was wrong. To be sure you could pull the access panel and watch the motor shift or lurch upon acceleration for verification, when I felt the first thump behind my butt on a harder than usual 1st to 2nd shift I immediately knew the culprit.
Old 04-28-2009, 09:13 PM   #8
is there any specific mileage where this usually goes out and should be replaced?
i had my car at the mechanic recently for a vacuum leak and they had the engine top cover off but no one said anything about my car needing a new motor mount. i'd like to hope that they would see it and tell me - not to make money but to just let me know things that need fixing - tjhey did notice water leaking off my water pump - very small amount - and they said i'd likely need a new one in the near future.... but no word was said of my motor mount...but that doesn't necessarily mean it's okay...
i do notice that when I go in reverse and then hit the brake, i get a small noticeable "clunk" that seems to come from the front of the car...not sure what that is...not a motor mount as that would be behind me...
Old 04-28-2009, 09:51 PM   #9
Lil bastard's Avatar
To be fair, you can't blame the mechanic. Anything they spot other than what you brought it in for is a bonus - and checking motor mounts is really off the radar.
The list of potential checks is endless and would ultimately end up costing you money because of the slowdown for the mechanic. To him/her, time is literally money and they'd have to make up for it somewhere!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-14-2009, 09:38 PM   #10
I replaced my engine mount on the weekend with an OEM one. The job is relatively straight forward if you have a decent set of tools. 15mm ring spanner very important as some of the bolts are impossible to access without this. I followed Pedro's instructions and the job took about 3 hours. I also changed the fuel filter while I was under there.
This has transformed the drivability of the car. Its amazing the difference it makes changing in and out or gear. You do not have to be as precise with the clutch for a smooth change with no jerkiness.
If you sometimes hear a clunking noise when you depress the clutch, then its pretty much your front mount thats gone.
kouks is offline   Reply With Quote
Old 06-15-2009, 03:18 AM   #11
Is the motor mount as much of a problem on a Tip car? If so what are the signs of mount failure? My 98 is approaching 60K and I want to start getting necessary replacement parts so that the winter down time can be productive. Thanks , Ed
cvhs18472 is offline   Reply With Quote
Old 06-15-2009, 05:03 AM   #12
Smile
I have a Pedro motor mount Works better than stock.. It the right one to pick!!
catmanluge is offline   Reply With Quote
Old 09-01-2009, 01:40 PM   #13
Bobiam's Avatar
I have an '01 with 39K on the clock. I've always noted that engaging the clutch in first gear was a rough and embarassing experience until it gets warm, but even then I have to feather it carefully. I thought it was me, but perhaps it's the mount.
I also find that when I shift to 2d at below 4000 rpm I have to give extra care to have it feel right.
I have always gotten the minor vibration going through the 3000 rpm mark when decelerating.
The car had 28K on it when I bought it 2 yrs ago and it felt the same. Never raced.
Do I need a front mount??????????
Bob
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
Old 09-01-2009, 01:53 PM   #14
07 Carrera S Cab
Boxtaboy's Avatar
Bob
People say the symptoms are you hear clunks, and shifting is more difficult, but I really didn't experience those symptoms. Instead, on my 01 Boxster, I noticed that under hard cornering (and in my case, hard right hand sweeping turns under power), I would get a really annoying grinding vibration from my left rear axle. Apparently, the driveline geometry was thrown off due to my worn out motor mount. This was what my motor mount looked like after it was out of the car at 58k miles. As you can see, there were several cracks in the rubber.
After the new updated 987 motor mount was installed, the grinding was gone, but I also noticed the vibration as you decelerate under 3k rpms was gone too. I'm very happy with the new mount, but it's been only 7 months with the new mount on. If it lasts another 58k miles before I need to change it, I can live with that, since I put less than 5K miles on the car per year.
Old 09-01-2009, 05:17 PM   #15
I went with the WEVO Semi Solid Mount and it vibrated a bit too much for me. So I went with the 987 mount. However if you like a very solid mount as a part of a track car, this is the ticket. I am thinking of selling it and I will throw in the carrier too, so it is a direct R&R. PM me if interested.
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
Old 09-01-2009, 09:00 PM   #16
Yeah, I changed it too last week. Clunks and shifting difficulty were the indicators in my case too. I chose the 987 one. My car is quiet now (I think...).
My life is a mess nowadays so I did it in a repair shop (I was doing the bearings anyway, so what the heck throw in some more $$$ ). If you ask them they can check it visually and tell you how bad it looks (the truth is I couldn't see much but they saw that it wasn't too bad, yet broken. $226 from pelican. $300-400 from the mechanic, $100-150 from pedro... the choice is all yours, but it is one of the (many) repairs you will enjoy
gstoli is offline   Reply With Quote
Old 09-03-2009, 03:35 AM   #17
Did mine this last weekend. What a difference. Took about 1.5 hours with a lift and a tranny jack and I used the sport mount. Thought it was too much vibration and engine noise at first but the more I drive it the more I like it. For most people I think the sport mount might be a bit much but I do the Chinmotorsports track drives and NASA HPDE drives with it. Much more solid feel.
mmontfort is offline   Reply With Quote
Old 09-21-2009, 10:15 AM   #18
Don't buy the Cheetahonline motor mount!!!
I bought one of these aftermarket mounts from cheetah and it failed 11months later...if you do get one good luck getting any support...no instruction, no phone number and no warranty!!! He also failed to mention that you have to take the old mount to a machine shop to knock out the sleeve before you can slip in his rubber sleeve..(if you need more info/pics check out my posts at renntech.org) Look into Pedro's Garage he makes a damn good mount for half the price (he also stands behind his product) or just buy OEM, the new OEM mount is beefed up so it won't fail like the old ones.
Regards,
Kamran
kamran66 is offline   Reply With Quote
Old 10-12-2009, 09:16 PM   #19
i was about to order the Pedro mount...now I"m reading there is a "beefed" up 987 mount...which apparently fits into our cars.
so which is "better" for an "enthusiast"? thge OEM mount that is the new beefed up 987 one, or the Pedro enthusiast mount or possibly his "race" mount..?????
my car is a weekend "toy"... i may track it once or twice a year...at MOST. it mostly sees "fun" spirited driving on back roads, twisty mountain roads, and the on/off ramps. no "real "racing is contemplated.... just fun spirited driving.
my car has 75k miles on th stock mount, i'm sure it's toast. part of me figures anything wil be an improverment..stock or Pedros..but I hear a lot of good stuff about Pedro's parts.... but if there is a "new" 987 part, maybe it's just as good and OEM?
any suggestions appreciated. thanks!
*update*
I just went online and foudn the 987 / cayman mount everyone was talking about. $228 at pelican. ouch. Pedros w/core is like $100. is the OEM worth another $128...i kinda doubt it!!!
anyone???
maybe the cayman one is softer/smoother just like the OEM one?
_____________________________
Cars:
2007 MDX - Wife's mommy mobile
2006 RL - My daily driver
2000 Boxster - Ocean Blue Base 5spd on Black Full leather. 18" wheels and M030.
Boxster mods I've added: Rear speaker kit, Painted Calipers, Painted Bumperettes, Painted Center Console, 987 Shifter Assembly, 3 Spoke Steering Wheel, Clear side markers, 03+ rear lights, de-snorkeled.
Old 10-13-2009, 12:29 AM   #20
I received my Pedro RaceMount today. Getting it installed Friday. Will post results then.
Daniel R is offline   Reply With Quote
