Old 03-26-2009, 09:55 PM   #4
Originally Posted by Boxster_luver
My Boxster does the exact same thing except mine is on the left hand side. I too stop folding the top up about 6-12 inches from being closed so I can fit it back in the groove. Happens every single time. J2da told me that it's just wear and tear, so I guess the only way to really fix it is to replace the top. I just ordered a new top so i'll let you know if it keeps doing it after I swap tops.
It's not necessary to replace the entire top to fix this problem. However, if you do replace the top and use the old shoulder plates and the tension cables from the old top, make sure that the overall length of the cables has not been exceeded.
Take a look at the link in the post below for the correct measurement of the cables when you replace the top. They can stretch out over time, but it's possible to re-size them if you don't want to replace with new ones.
Regards, Maurice.
schoir is online now   Reply With Quote
