Old 12-21-2008, 09:08 PM   #1
Brake Wear light????
I was at the track when my "Brake Wear" light came on and stayed on. Had the mechanic checks all brakes and wear sensors, he says they are all good. The dealer wants $300 just to look at it.
Any ideas???
CBAD-986 is offline   Reply With Quote
Old 12-22-2008, 08:03 PM   #2
Lil bastard's Avatar
How is the pedal feel? Have you blown the master cylinder?
Also, did the mechanic just do a visual test on the wear sensors? The actual wire can easily break inside the teflon sheath. I would do a continuity test on each one with a DMM. All you'd need to do is disconnect the electrical connector and test for continuity between the pins. My suspicion is that this is the problem.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 12-25-2008, 12:12 PM   #3
this issue has happened on a friend of mines car and it was indeed the wire. he said it was a cheap fix though.
-Jeff-
"I'm a glutton for punishment when it comes to my boxster"
'03 S/ PSS9/ B&M short throw/ EVOMS intake/ NHP full exhaust w/ headers / Cantrell MS custom tune
boxster_s_boy_34 is offline   Reply With Quote
Old 12-26-2008, 05:10 PM   #4
brake sensors
I talked with the mechanic and he stated they did a resistance test on each sensor and it all looked good. They checked the system up to the computer and that checked out. He believes the problem is between the computer and the dash.
He talked to a porsche mechanic in LA and was told that sometomes flashing the computer will fix it and other times they have been required to replace the instrument cluster????
Thanks for the sugestions
