Old 12-01-2008, 08:37 AM   #1
Control arm bushings
I have searched the forum and gotten no hits even though I know I have seen "control arm bushings" in threads...I have seen someone (Randall?) attribute the awful groaning sound over low speed bumps to warn control arm bushings, and I was wondering if there is a good aftermarket replacement for the bushings only or if one needs to spring for fancy aftermarket control arms? I googled it and have not had much luck finding bushings.
dmcutter is offline   Reply With Quote
Old 12-01-2008, 01:14 PM   #2
Powerflex makes some .
Dave
dcdrechsel is offline   Reply With Quote
Old 12-01-2008, 03:21 PM   #3
Thanks. OMG, "warn control arm bushings...". How mortifying. Obviously, should be "worn".
Old 12-01-2008, 04:00 PM   #4
Are you a member over on the Renntech.org forum?
Lots of technical info including this little gem regarding that noise as it relates to the rear control arms: Boxster Control Arm Repair, Boxster Rear Control Arm Repair
kabel
kabel is offline   Reply With Quote
