10-19-2008, 02:12 PM
98 Boxster. Wont crank, wont start
It's me again. My 98 Boxster will not turn over. When I turn the key, the accessories all come on. But the engine will not turn over. I have replaced the ignition switch, checked the relays, and replaced the battery.
The engine is not seized, as I heard it turning when I attempted to push-start.
Need help!
thxx,
sam
macyfilms@aol.com
10-19-2008, 02:33 PM
Bad starter?
10-19-2008, 06:47 PM
Porsche "Purist"
Push the clutch pedal harder? Do you have a floor mat under it?
1987 924S. 2002 996TT. PST-2
10-19-2008, 08:42 PM
clutch switch
I checked the clutch switch, it's definately popping out as it should when i push the pedal down.
Can I access the starter from under the car to test that out?
10-19-2008, 08:51 PM
Porsche "Purist"
Check the clutch switch with a volt ohm meter.
10-20-2008, 07:21 PM
Porsche "Purist"
The starter and solenoid are on top of the motor.
10-22-2008, 08:27 PM
manual page
HI Paul,
I tried to send you a private message, but the system told me your box was full.
Sam (starter/solenoid problem)
macyfilms@gmail.com
(if you got any documentation on a quick and painless way to open my top (stopped working) would love that too!
thx,
sam
10-22-2008, 08:43 PM
Porsche "Purist"
Email sent, inbox cleaned up.
10-22-2008, 08:53 PM
Porsche "Purist"
This type of starting issue can also be caused by using a key whose transponder code does match the immobilizer.
10-22-2008, 09:09 PM
key/transponder
I thought about that key-transponder issue, but it's the same key I've been using for ten years. Is it possible that when my battery went totally dead i created a code or immobilizer issue?
i should mention that when my battery was totally dead, i had to put juice in through the cigarette lighter to get the hood unlocked.
sam
