Old 10-24-2008, 07:25 PM   #21
Originally Posted by Jaxonalden
You should get away with about $40 in parts and whatever it takes in time for you to pull your plugs. Your problem should be a wake-up call for the rest of us with time and mileage on our cars. I'm ordering a set of tubes and O-rings so the next time I change my plugs, I'm replacing my tubes as well.
Thanks Jaxonalden. I have ordered the tubes and will let you know how it went once I get them in!
Mike
Michael
http://imgur.com/aiZcIk8
986FortyEight is offline   Reply With Quote
Old 10-24-2008, 10:37 PM   #22
Lil bastard's Avatar
Absolutely no reason to swap the tubes! It's the 'O' rings which go bad... not the tubes... they're just tubes. Unless you find a cracked tube (which I have never heard of) simply replacing the 'O' rings should be sufficient.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 11-01-2008, 04:28 AM   #23
Just a thought
I just thought that I would throw in my 2 cents here. I know that flat 6's are well known for seeping a little bit of oil from the valve seats if they sit for any length of time (within a day or two is possible) and that will cause a little bit of smoke on start up. I know that nobody enjoys working on a hot engine, so I'm wondering how much oil would you say it was, and how long did the car sit prior to changing the spark plugs?
-Jeff
boxster_s_boy_34 is offline   Reply With Quote
Old 11-01-2008, 02:28 PM   #24
Jaxonalden's Avatar
-Jeff
The two things your talking about have no relation to one another. The smoke at start up is from oil seeping past the rings and burning at start up. The oil in the spark plug tubes is from leaking o-rings that seal the spark plug tubes in the head.
Old 11-01-2008, 06:15 PM   #25
I tried
Well, like I said it was my 2 cents and I don't know a whole lot about these water cooled 6's. As for my smoke explanation; that is what I was told by Matt at Sport Haus in Reno (surely someone has heard of them because they are world reknowned for their turbo work).
-Jeff-
"I'm a glutton for punishment when it comes to my boxster"
'03 S/ PSS9/ B&M short throw/ EVOMS intake/ NHP full exhaust w/ headers / Cantrell MS custom tune
Old 11-01-2008, 06:16 PM   #26
I tried
Well, like I said it was my 2 cents and I don't know a whole lot about these water cooled 6's. As for my smoke explanation; that is what I was told by Matt at Sport Haus in Reno (surely someone has heard of them because they are world reknowned for their turbo work). The more I get on here though, the more that I learn everyday, even if it is tough love. Thanks for the mentorship.
-Jeff-
Old 11-01-2008, 06:30 PM   #27
Porsche "Purist"
Paul's Avatar
I'm sure he said "valve seals" not "valve seats."
But even so, nothing to do with this issue.
1987 924S. 2002 996TT. PST-2
