Old 08-04-2008, 11:47 AM   #41
Gary, I'm on the horn with them (on hold, of course) right now.
I'm asking how much 7 kg rear springs cost and how to install the helper springs on the rear, etc.
This is what Kevin (Insite) told me to buy on the phone just now when we spoke.
I'll post the info here when I find this out
Old 08-04-2008, 02:45 PM   #42
Those thin tender springs don't add anything to the effective spring rate, and will be compressed flat at ride height. They just keep the main spring from rattling and coming off of the perch when the suspension is fully extended.
Steve
Old 08-04-2008, 02:50 PM   #43
Rennzenn
j.fro's Avatar
Hey Insite, the shocks you showed in the photo are the ones I've got for my car. They are threaded above the collar, but not below it. The collars are fixed solid as a rock.
j.fro is online now   Reply With Quote
Old 08-04-2008, 03:30 PM   #44
Originally Posted by stephen wilson
Those thin HELPER springs don't add anything to the effective spring rate, and will be compressed flat at ride height. They just keep the main spring from rattling and coming off of the perch when the suspension is fully extended.
Steve
i figured they were TENDER rather than HELPER springs. randall - when you talk to ksport, maybe ask about this. TENDER springs will aid in high frequency bump damping; the HELPERS are good for exactly what stephen said.
EDIT: reversed tender / helper to reflect proper nomenclature.
insite
'99 Boxster
3.4L Conversion
Old 08-04-2008, 07:10 PM   #45
They are tenders, not helpers.
The Ksport guy sold me 7 kg springs for the back to replace the 10's. The fronts are 5.5... according to him.
There is evidently no separate ride height adjustment for the coilovers designed for our cars.
I am still completely lost on how to set them up as the instructions are total crap. Kevin, please document the install with LOTS of photos.
Old 08-04-2008, 08:07 PM   #46
randall - can you measure the inner diameter of your springs? i think i'll buy some helper springs ahead of time so i can install w/ my setup. don't worry; i'll take a lot of photos.
insite
'99 Boxster
3.4L Conversion
Old 08-05-2008, 06:14 AM   #47
Kevin, we're expecting a storm here in Houston today and both my employees asked if we could work out of the house today... which translates to the wife and golden retriever went on a weather-related strike.
So, I am at home and the coilovers are at my office. I will probably drive over some time this morning and I'll measure them for you.
I'm also going to take pix of the tops of the units so I can do before and after mods you recommended and show you my work so you can OK it before I give them to my mechanic.
Old 08-05-2008, 06:46 AM   #48
sounds good. the easiest way to measure the inner diameter of the springs will be to measure the OUTER diameter of the tender spring spacers. they will either be 2.25", 2.50", or metric.
insite
'99 Boxster
3.4L Conversion
Old 08-06-2008, 07:49 AM   #49
The helper springs have an inside diameter of 63mm or 2.5 inches. The outside diameter is 83mm or 3.25 inches.
Overall height is 56mm or 2 3/8 inches sans the separator ring
Old 08-06-2008, 08:19 AM   #50
Kevin, it's time to pry more knowledge out of your head about these coilovers. I know this will take some time, but if you can answer my questions once here with these pics, you will not be badgered by other forum members in the future
Here we go.
In this first photo, we see all the tools and bushings sent with the coilovers. Please explain what each of them do, how they're used, why I have six of one tool, two of another, only six rubber bushings, do the bushings go on the fronts or the rears, do the bushings go between the tops of the strut mounting plate and body or under then nut inside the trunk area, etc. There were ZERO instructions on this in the box.
In this second photo, we have a shot of the back strut. Please explain which direction I should move the strut... toward A or B? One other question... is the B side the outside or the inside?
In this last photo, we have a shot of the front strut. This one will be more complicated to explain, but I have questions as well. Is the A or B side the outside? Do I loosen the bolts and move the strut toward A or B? Where should the bolts C or D reside when they're in the right place?
I've barely got enough cash scraped together to get them installed right the first time, so I don't want to be forced to remove them for any reason to fix something I didn't get right. What I will do is to do the setup mods you mentioned earlier after a response and photograph them and post pics of the mod for your approval if that's ok with you.
Old 08-06-2008, 08:33 AM   #51
okay, first photo.
'A' are for adjusting the damping. they go in the top of the struts. make sure you put the rear adjusters into the struts BEFORE you install them; you won't be able to get them on afterward.
'B' and 'C' go together. some cars have brake line brackets attached to the struts. these are replacement brake line brackets. you put 'B' around a brake line and then insert 'B' into the forked end of 'C'. you then bend it to whatever position you need and bolt it to the strut. in our case, the brake lines are held at the chassis. we DO, however, have brake wear sensors that these parts could be used for. i have no idea why they gave you six of each.
'D' are the spanner wrenches; they are used to adjust ride height. they're designed to turn those toothed collars up and down the strut housing.
in the photo of the front camber plates, 'A' will be outboard. loosen 'C' and 'D', then slide everything outboard until 'C' is halfway between where 'C' and 'A' are in the picture.
i have to go out and look at my rear struts before i can tell you how to adjust the rears. technically, if you have adjustable toe links, it's not necessary to move them. i'll tell you how to reduce overall camber with them, anyway. i'll post in a bit.
insite
'99 Boxster
3.4L Conversion
Old 08-06-2008, 08:51 AM   #52
okay, first photo.
Are you saying here that with Ksports the rear dampening can not be adjusted with the coil overs installed?
On my 99 I can adjust the dampening if my front and rear coilovers with them on the car.
Speaking of this, after we talked the other day about going with a lesser spring rate I went full soft on my rear coilovers and the driving I have done so far the car seems better. I am going to get the lesser spring rates and hope it solves my suspension issues.
Thanks guys.
99 TWIN TURBO Boxster 175k+ miles
Growing up the car magazines said how amazing Porsches are. Was I brainwashed? Somehow...I doubt it.
http://www.pcars.us/albums/10641_porsche_cars.jpg
Gary in BR is offline   Reply With Quote
Old 08-06-2008, 09:06 AM   #53
Gary, I think Kevin is saying the orange knob thingy will not fit into the top of the strut through the hole in the bodywork (sheetmetal) of the boxster and it must be inserted before the strut is installed.
I think there's enough room to get your finger in there and move it around, but not enough room to slide it fully into place. Kevin, correct me if I'm wrong on this so I can learn too.
Old 08-06-2008, 09:10 AM   #54
correct. there's plenty of room to adjust them, but not enough room to remove or insert the tool, so it needs to be inserted ahead of time and left in place.
i think it's POSSIBLE to insert the tool with the struts in, but you have to bend it a lot. better to just put it in first.
insite
'99 Boxster
3.4L Conversion
Old 08-06-2008, 09:21 AM   #55
In mine I am able to get the orange knoby allen wrench in and I able to turn it. Maybe I have smaller hands...my poor wife.
Old 08-06-2008, 09:33 AM   #56
OK I am in on these as long as I get the word from all of you that these are good. Insite how long have you been running these? Initial reaction is that they are too good to be true.
Maybe a GB could be in order?????
JP
Everything is for sale
3.6, SC 'er and other parts for sale
JP-s-in st. louis is offline   Reply With Quote
Old 08-06-2008, 10:25 AM   #57
i don't have them installed yet; they are on order. they SHOULD arrive sometime next week. if they do, i will install them next weekend. once they're dialed in, i'll post installation notes and street driving impressions.
a couple of weeks after that, i will take them to the track and post race driving impressions.
insite
'99 Boxster
3.4L Conversion
Old 08-06-2008, 10:41 AM   #58
okay, i went out and looked. in the picture below, 'B' will be inboard. you'll want to move the pillow ball to position 'A'.
on another note, i did a little more research into helper / tender springs. first of all, i had the nomenclature wrong. TENDER springs are softer springs that help w/ bumps. HELPER springs keep the main springs seated when the suspension is fully extended. without them, at certain ride heights the main springs might come unseated and make noise.
anyway, TENDER springs are what will improve the ride quality. both Eibach and Hyperco make some that are commercially available. they are 3" in length, so we MIGHT need shorter main springs. i will no more when i actually have my KSports sitting in my lap. TENDER springs can be ordered in various spring rates, usually from about 150lb to 400lb.
i will likely install my KSports with the factory provided tender springs and see how the ride is before i make a decision on tenders.
insite
'99 Boxster
3.4L Conversion
Old 08-07-2008, 04:57 PM   #59
Rennzenn
j.fro's Avatar
With all of the settings/adjustability on these shocks, I'd like to suggest that we post some of our alignment numbers, particularly camber settings. Here goes:
My ride height was set at 1" lower than stock
The front shocks were centered in their camber plate settings; camber came to -1.5 with both pushed as far inboard on the body mounting as they would go.
Toe was 0.04
The rear shocks were also centered in their camber plates; camber was -2.2
The closest I could get to zero rear toe was - 0.31
I'm very curious to know what the camber settings would be in the rear with them at both the next setting and farthest inboard setting.
Old 08-08-2008, 06:30 AM   #60
J.fro, this is a good idea.
Kevin, I'm going to post my alignment numbers here later today so you can see my minor subframe damage problems on the driver's side of my car. It may change the advice you are giving me as to how to set up my coilovers prior to installation.
Basically, the numbers are a bit out of range on one side of the car and one of my hopes in installing the adjustable toe arms and making these coilover setups will alleviate the problem.
