Old 06-15-2008, 05:35 AM   #1
I have 39,759 miles on my Boxster and my pads look less than half way worn. I measured my left front rotor and got 26.49mm and decided to post to find out what this means for me.
For the Boxster S new rotor thickness is 28mm Front and 24mm Rear. The wear limit is 26mm Front and 22mm Rear. So you've got 2mm from new to wear limit?
Then there is a machining limit which is about 0.6mm thinner than the wear limit for the Non-S Boxster. Does anyone know what it is for the S rotor?
What exactly is the "wear limit" ? It's not the point at which you need your rotor's cut is it? Can't be after only 2mm ?
Is the "machining limit" the point where you have to buy new rotors?
My Bentley's shows the machining limit for the Non-S Boxster rotors at 22mm Front and 18mm Rear. They don't provide this data for the S model.
Am I only 0.49mm from having to turn my rotors? How long will that 0.49 last me?
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
Old 06-15-2008, 09:35 AM   #2
Lil bastard's Avatar
Boxster 'S' data is 28mm (Fr), 24mm (Rr) w/ minimum thickness (wear Limit) of 26mm and 24mm respectively. Yes, you have 2mm new-to-wear limit. 2mm of 'gray' iron takes quite a while to wear away, and don't forget, the pads are wearing away at a rate of 3:1.
The wear limit is the point where your rotors should be replaced. This keeps the brakes operating at maximum and properly. Wear too thin and not only do you risk having a rotor fail, but you over-extend the caliper pistons, allowing them to corrode and tear the seals.
The machining limit is the absolute limit in terms of maintaining the rotor's integrity - you do not ever want to use this limit - replace at the wear limit. The Machining limit is provided to guide the operator in turning the rotor for lateral runout.
How long will .49mm last? Depends on your driving habits and type of brake pads used. But, do the math... you started at 28mm and 40k mi. later, you're down to 26.49mm. That works out to 0.0000377mm/mi. and given that, about 13k mi. from now you'll have worn away the remaining .49mm.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-15-2008, 10:09 AM   #3
Thank you Lil Bastard, you're right, all I had to do was the math.
I was just missing a piece of information for my equation that you now gave me. That 2mm of metal off the rotor is all you get.
Since I moved back to New York from California (back in 2006) I only put on about 2,000 miles a year. At that rate I won't have to buy new rotors for 6 years! But since my new found interest in DE and AutoX I guess it will be more like 1 year or two summers.
