Old 06-15-2008, 05:35 AM   #1
2000SoCalBoxsterS
I have 39,759 miles on my Boxster and my pads look less than half way worn. I measured my left front rotor and got 26.49mm and decided to post to find out what this means for me.
For the Boxster S new rotor thickness is 28mm Front and 24mm Rear. The wear limit is 26mm Front and 22mm Rear. So you've got 2mm from new to wear limit?
Then there is a machining limit which is about 0.6mm thinner than the wear limit for the Non-S Boxster. Does anyone know what it is for the S rotor?
What exactly is the "wear limit" ? It's not the point at which you need your rotor's cut is it? Can't be after only 2mm ?
Is the "machining limit" the point where you have to buy new rotors?
My Bentley's shows the machining limit for the Non-S Boxster rotors at 22mm Front and 18mm Rear. They don't provide this data for the S model.
Am I only 0.49mm from having to turn my rotors? How long will that 0.49 last me?
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
