Old 06-09-2008, 07:53 AM   #1
Rear suspension questions
I'm rebuilding the rear suspension on my 97 boxster and I have some questions.
There appears to be three bits to the suspension on each side.
#8 - Track Control Arm
#9 - Lower Control Arm
#17 - Track Rod
Which one of these is the one that goes out and makes the car "clunk" when it's driven over a bump?
I know I have a worn out #9 Lower Control arm on the passenger side and while I'm getting stuff replaced, I'm going to the other one that seems to wear out and cause the clunking sound.
Old 06-09-2008, 09:45 AM   #2
Its #8 Upper Control Arm/Track Arm which goes out and causes the clunk
#9 is a Lower Control Arm
#17 is a Rear Toe Arm
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 06-09-2008, 10:16 AM   #3
CJ, I'm thinking about installing KSport coilovers as well, but have concerns:
1. Will I have alignment issues if I don't install the adjustable stuff from Che?
2. The other thread showed that Che's adjustable rear toe arm doesn't fit well.
I have one other unrelated question.
3. Should I go ahead and change out the toe arm since we're in there and the car has 105k hard miles on it?
Can you give me some guidance on these issues?
Old 06-09-2008, 10:28 AM   #4
Yes, replace both sides at the same time, You can use Che's Upper control arms, It's what im using and i love them... Since you are lowering the car with the coilovers you would need an alignment and the 1 problem you will get (aside from camber) is your rear toe will be maxed and too far positive... or negative, i forget but there are 2 ways or curing that problem.
1) Buying Ches adjustible Toe arms (aside from fitment) are good arms.
2) Adjusting the new adjustible Upper Control arms forward which will increase your rear wheel caster and undo the excessive rear toe.... Which is what i did. If you do this, make sure you adjust both Upper control arms forward EVENLY, since this probably isnt an ideal setup for the boxster, you atleast want the caster to be even on both sides.
Carlos J Cazares
Old 06-09-2008, 11:16 AM   #5
CJ, this is great info. Thanks so much for taking the time to offer it.
I am now thinking that doing the coilovers will be more expensive than just buying the coilovers themselves and hard to get the car into alignment without going to a speed shop of some sort. I just might pass on it. It was mostly for looks anyway, and my side skirts make the car look lower than it really is.
Old 06-09-2008, 11:38 AM   #6
No prblem, thats what Im here for.
Carlos J Cazares
