Old 05-16-2008, 05:55 PM   #1
EUC flash loader
tell me what you guys think about this?
http://www.************************************************************/productpage.aspx?cid=2&sid=35&pid=112465#partStart
think CEL can be taken out?
fu03steve is offline   Reply With Quote
Old 05-17-2008, 04:07 AM   #2
Steve,
I attended a PCA meeting last week at Musante Motors in Connecticut. They did a presentation on ECU flashing.
This is what I discovered:
ECO Flashing works well on Turbo cars. This is because you can increase the turbo boost. They had a 996 Turbo which indicated and increase of 75 HP on the dyno.
I asked the owner of Musante what affect flashing has on normally aspirated cars and he said mid range power will have a slight increase 5-7 HP, but overall HP does not increase.
Hope this helps.
JFERRhttp:
Only problem with a Porsche is the traffic.
JFERR is offline   Reply With Quote
Old 05-17-2008, 07:31 AM   #3
Originally Posted by JFERR
Steve,
Hope this helps.
all true unless you've done a lot of mods to your car, particularly if it's a 2.5L. if you've done a lot of mods, it's necessary to widen the ECU parameters to take full advantage of the mods.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
