Old 03-16-2008, 07:46 AM   #1
Porschephile
Tomikaze's Avatar
987 cross drilled rotors on a 986??
Anyone know if this is an easy mod? I want an OEM cross drilled rotor without having to upgrade my calipers. In my research I'm pretty sure the base 987 uses the same calipers as a base 986. Would I be safe to assume then the cross drilled rotors from the 987 would be a direct swap? Thanks in advance. -Tom
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
Old 03-16-2008, 08:59 AM   #2
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Tom
The front rotors are a straight swap between the 986 & 987. I recently did this exact setup on my 2001.
The Rear however will not fit. The diameter on the hub of the rear 987 is too big to fit the 986.
I had a set of Zimmerman Cross drilled installed on the rear to match. If you do get the zimmerman rear rotors make sure to paint the hat to match the OEM 987 front.
http://i46.tinypic.com/2qx0rqs.jpg
2001 Boxster Artic Silver / Black Interior
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-Michilen PS Tires 225/40/18 & 285/30/18
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Pioneer Avic-F90BT Navigation
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Bose OEM Subwoofer & Midrange
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 03-16-2008, 10:35 AM   #3
Porschephile
Tomikaze's Avatar
Thank you for your answer. How about the rear rotors from a 986 S? Will those fit on a base 986?
Originally Posted by TriGem2k
Tom
Portland, Maine
Old 03-16-2008, 07:32 PM   #4
Lil bastard's Avatar
No they won't. The Base rotors are 298mm vs 318mm for the 'S' (Fr) and 292mm Base vs 299mm 'S' (Rr).
While you may be able to get it on the hub, the calipers won't reach the brackets.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-17-2008, 07:40 AM   #5
Tom
Will this work with a 2000 base 986 too?
tracke30m3 is offline   Reply With Quote
Old 03-17-2008, 11:27 AM   #6
TriGem2k's Avatar
Yes.
1997-2004 Base models can use the 987 Base Front Rotors with no issues
-Side Skirts
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Alpine PDX 5 Amp
